• Support PF! Buy your school textbooks, materials and every day products Here!
Angle Ratios
1. Homework Statement
Tree A is 10 m tall. Tree B is 60 m tall. You're standing on level ground at a position that is 25 m from tree A and 75 m from tree B. You're eye height is 1.5 m above the ground. Find the ratio of theta B/ theta A, of the angles (measured from the horizontal) at which you must look to view the top of each tree.
2. Homework Equations
tan(theta) tan -1 (theta)
3. The Attempt at a Solution
I think I have found both angles A and B: A = 18.8 degrees B = 37.95 degrees
This is absolutely crazy that I don't know how to find the B/A ratio! do I just put 37.95/18.8? Or do I need to divide both of them by 90 first, since the overall angle is a horizontal?
Thanks in advance.
Answers and Replies
dlgoff
1,640
"B/A ratio"
It's just as you have shown B divided by A. i.e. 37.95/18.8 (note I didn't check you math for these angles)
thank you! do these angles sound reasonable?
dlgoff
1,640
How did you get these angles? What is the relation between the height of the tree, the distance from the tree and the angle?
With everything I knew I was able to form two triangles and in each I knew two sides. A: 8.5 and 25 and hypotenuse unknown. B: 58.5 and 75 and hypotenuse unknown. Using the tangent inverse, I found theta for each.
dlgoff
1,640
You got it. Good job.
Thank you =]
Related Threads for: Angle Ratios
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
