Homework Help: Angle to LEED spots
  1. Oct 27, 2013 #1
    A 100eV electron beam is normally incident on an unreconstructed Si(001) surface. Calculate the angle from the surface normal to the (1, 0) and (1, 1) LEED spots (the spots are indexed using the surface unit cell)
    Si cubic latice parameter is 5.43072 angstroms
    2. Relevant equations
    Can calculate the wavelength in angstroms of the electron beam using [itex] λ = \frac{12.3}{√E} [/itex] where E is in eV. And hence wave vector [itex] k = \frac{2π}{λ} [/itex]
    3. The attempt at a solution
    I have used the Ewald sphere construction to calculate the angle, θ, to the (1, 0) LEED spot in terms of the wave vector, k , and the reciprocal lattice constant, b. [tex] b = \frac{2π}{5.43072} = 1.157 [/tex] [tex] k = \frac{2π}{1.23} = 5.108 [/tex]
    Hence [itex] θ = arctan \frac{b}{k} = arctan \frac{1.157}{5.108} = 12.76°[/itex]
    And then to the (1, 1) spot I used √2b instead of just b in the first part to find the angle = 17.76 degrees.
    I'm very uncertain of my method and the answers. Are they correct? Thanks in advance
  3. Oct 28, 2013 #2
    Bump. Would this be better moved to a different board?
Have something to add?
Draft saved Draft deleted
Loading...
