Can You Calculate Angles from Graph Coordinates and Slopes?
In summary, the conversation discusses the calculation of angles from the slope or coordinates of a graph. It is possible to find the angles between points at various coordinates by using the tangent formula. The participants also clarify that slope and tangent are related and can be used to find the angle.
darkelf
77
Hi,
Is there a way of calulating the angles from the slope or coordinates of a graph. Say you have a bunch of x and y coordinates and you want to find the angles between those points at various coordinates (say every x,y ratio) can it be done?
How would you go about it?
Mathematics news on Phys.org
yes,why not. :)
Angle between lines joining [tex](x_1,y_1) \&\(x_2,y_2)=tan^{-1}\left( \frac{y_2-y_1}{x_2-x_1}\right)[/tex]
Angles between lines joining? If you have a single slope that doesn't intercept at the x or y axis?
Have another look at skand's answer. Slope means rise over run, right? So if you have the slope, then you have the tangent of the angle.
1. What is the difference between an angle and a graph?
An angle is a measure of the rotation between two intersecting lines, while a graph is a visual representation of data using points, lines, and curves.
2. How do you calculate the degrees of an angle?
The degrees of an angle can be calculated by dividing the circumference of a circle by 360 and multiplying it by the angle's measure in degrees.
3. What is a vertex in an angle?
A vertex is the point where two lines or rays intersect to form an angle.
4. How are angles typically measured?
Angles are typically measured in degrees, with a full rotation being 360 degrees.
5. What is the relationship between angles and graphs?
Angles can be represented on graphs using coordinates, and angles can also be used to measure the slope of a line on a graph.
  • General Math
  • General Math
