1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Angular acceleration and tension
  1. Dec 3, 2007 #1
    A uniform rod of length L and mass m is supported as shown in the figure. A vertical cable at A suddenly breaks. Determine at this instant the angular acceleration of the rod and the tension in cables AE and BF.
    2. Relevant equations
    mass moment of intertia of bar: 1/12mL^2
    summation of forces
    relative accelerations
    3. The attempt at a solution
    attempt is in picture
    stuck at this point
    http://img228.imageshack.us/my.php?image=82wv8.jpg
  3. Dec 3, 2007 #2
    Gokul43201
    Staff Emeritus
    I don't see the "vertical cable at A" in the picture. Is the picture drawn after this cable has broken?
  4. Dec 3, 2007 #3
    Yes, vertical cable at A is not drawn in because it has broken. I don't think this cable works into the equations at all.
  5. Dec 3, 2007 #4
    Gokul43201
    Staff Emeritus
    No, you definitely need to use that information. The tensions in the other cables at the instant of breaking depends on the existence of the vertical cable at A. A fraction of a second later, the tensions in the other cables will readjust to make up for the loss of the first cable. You want to study the system before this readjustment happens.
    First draw the picture with the vertical cable at A. You will immediately notice something (by inspection) about the tension in cable AE. You can also solve for the tension in BF. You then need to use these values and set the tension in the vertical cable at A = zero to determine the instantaneous acceleration of the rod.
  6. Oct 11, 2011 #5
    The tension in the rod doesn't matter because tension cannot effect angular acceleration. To solve this problem you basically have the mass move about the rod. Force of gravity translates into torque. Torque translates into angular acceleration. Technical you could do it without knowing the mass either.
Similar Discussions: Angular acceleration and tension
Loading...
