helpme101
- 4
The rotating subunits forms an approximately cylindrical axel with a diameter of 4 nm and total mass of 80,000 Daltons. The motor takes three steps per revolution with each step taking 0.067 s. We can model the rotating subunits as a rotating cylinder and use the properties described above to calculate:
A. The angular acceleration of the motor during each step (Assume the motor pauses very briefly between steps and therefore starts each step from rest)
B. The torque needed to generate the acceleration calculated in (a). Hint: you will need to determine the moment of inertia first.
A. Angular acceleration = change in angular velocity/ time interval
Angular velocity = 2 X pi radians X F
F=1/period
B. Torque = rF
Using the answer we found in part A the equation would be: angular acceleration = Torque/mr^2
A. Period = 0.067 s X 3 steps = .201 s
Frequency= 1/period = 1/.201s = 4.97512 s^-1
angular velocity = 2 X pi X 4.97512 s-1 = 31.2592 rad s-1
so angular acceleration = 31.2592 rad s-1 / 0.067 s - 0 s = 466.561 rads-2
B. 4nm=.000000004 m = diameter
.000000002 m = radius
80000 Daltons = 1.328 X 10 ^-22 kg
466.561 rad s^-2 = Torque/ (1.328 x 10^-22 kg) (.000000002 m)^2
= 2.47837 x 10^-37 Nxm
