Angular Acceleration and tangential acceleration
In summary, the conversation discusses the relationship between tangential acceleration and angular acceleration, as well as the vector components of these quantities. It is explained that the equation Ar = At/R is not a vector equation because it does not take into account the direction of the vectors. The concept of angular displacement as a vector is also mentioned, but it would require unit vectors for radius and angle. The conversation concludes by mentioning the vector equation for angular motion and recommending further reading on the topic.
Seph
Hmmm. I have a question...
We know that the tangential acceleration (At) is equal to the radius (R) multiplied by angular acceleration (Ar), of which At and Ar are vector components.
At = R Ar
Then I was told that Ar = At/R is not a vector equation. Why is that true?
~Seph :confused:
Well mainly, because those relations refer to the magnitude of those vectors, the problem is angle displacement does not work with vectorial addition communitative property, but as it gets smaller it works with vectorial addition, that's why angular velocity and aceleration are vectors.
Also, you could define angular displacement as a vector, but you will need an unit vector for the radius and the angle, so you will give them direction.
Your equation is one component of the basic vector equation for angular motion:
V = omega X R where v is the velocity vector, omega is the angular velocity vector, and R is the position vector , and X indicates the vector cross product. (If an object is rotating around the z axis, then the omega vector points along the positive z axis for counterclockwise rotations.)
This vector approach is discussed in Resnik and Halliday, and in most more advanced texts on mechanics.
Regards,
Reilly Atkinson
1. What is the difference between angular acceleration and tangential acceleration?
Angular acceleration is the rate of change of angular velocity, while tangential acceleration is the rate of change of tangential velocity. Angular acceleration is a measure of how fast an object is rotating, while tangential acceleration is a measure of how fast an object is moving in a circular path.
2. How is angular acceleration calculated?
Angular acceleration is calculated by dividing the change in angular velocity by the change in time. It can also be calculated by taking the second derivative of angular displacement with respect to time.
3. Can an object have angular acceleration without tangential acceleration?
Yes, an object can have angular acceleration without tangential acceleration if it is rotating without changing its speed. This is known as uniform circular motion, where the tangential velocity remains constant but the direction of the velocity is changing.
4. How does angular acceleration affect an object's motion?
Angular acceleration affects an object's motion by causing it to either speed up or slow down its rotational motion. It also determines the direction of the object's rotational motion.
5. What are some real-life examples of angular acceleration and tangential acceleration?
Some real-life examples of angular acceleration include a spinning top, a rotating wheel on a car, and a figure skater spinning on ice. Tangential acceleration can be seen in a car driving around a curved road, a satellite orbiting the Earth, and a roller coaster moving along a circular track.
  • Mechanics
