Angular Acceleration
  1. Jun 19, 2005 #1
    1) A solid cylinder of mass M = 1.14 kg and radius R = 6.3 cm pivots on a thin, fixed, frictionless bearing (see Figure). A string wrapped around the cylinder pulls downward with a force F = 4.606 N. What is the magnitude of the angular acceleration of the cylinder? Use units of "rad/s\^{}2".
    2)Consider that instead of the force F, a block with mass m = 0.47 kg (with force F = 4.606 N) is attached to the cylinder with a massless string (see Figure). What is now the magnitude of the angular acceleration of the cylinder? Use units of "rad/s\^{}2".
    3)How far does mass m travel downward between t = 0.51 s and t = 0.71 s (Assuming motion begins at time t = 0.0 s)?
  3. Jun 20, 2005 #2
    1)
    [itex]
    T=I a
    where T = rF sinQ
    [/itex]
    Use the expression for MI of the cylinder and calculate the torque and put the values in the above expression.
    2) Try to use the Free Body Diagram , the same expressions as above will be applicable , in this case the force 'F' will change.Try i out and show your work here.
    B.J
