Angular coeficient
  • Thread starter amarante
What is the angular coeficient of a straight line that passes through (4,3), if it satifies x>0 and y>0, and it is one of the sides of a triangle with total area of 27 (units of area).
calcule o coeficiente angular de um reta que passe por (4,3) de modo que a parte da reta no primeiro quadrante forma um triângulo de área 27 com os eixos coordenados positivos.
I know that the area of a triangle is area = base * height/2 . I know the equation of the straigh line is y = aX + B, where "a" is what I am looking for. But I am stucked! I cant find a nice relation.
I've tried to use the relation Area = 1/2 * D
Where D is the determinant of a matrix with the 3 vertices of the triangle, with an aditional columns of "1". But, couldn't go any further... any ideas?
Answers and Replies
LCKurtz
Insights Author
773
I assume the axes form the other two sides of the triangle. Write the equation of the line though ##(4,3)## with slope ##a##. Its ##x## and ##y## intercepts will give you the base and height in terms of ##a##. Then set the area, now in terms of ##a##, equal to 27 and solve for ##a##.
Perfect! I got it. Thank you so much!
I got a solution with two possibilities, a= -1.5, or a = -0.375.
Thanks!!!
Related Threads on Angular coeficient
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
