1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Angular Kinematic problem:
  1. Oct 8, 2008 #1
    1. You have recently been struggling when stepping up to the plate to bat. You can no longer hit for power. To combat the problem you go see Bobby the bat boy and ask him for "Wonder Boy." This bat is 1.5 inch longer than the bat you currently use.
    Assume that:
    -you can swing both bats with an angular velocity of 2200 degree/s.
    -including your arms and the length of your old bat--the radius of your swing 130 cm (to the contact point on the bat).
    -your bat makes contact with the ball 1.2 m above the ground.
    How much farther will you be able to hit a pitch with "Wonder Boy" which leaves your bat at an angle of 45 degrees if you measure the distance to the point where it lands on the ground?
    2. ANGULAR VELOCITY: change in theta/change in time, ARCLENTH: Theta(radius), Vt=angular velocity(r), At=(angular acceleration)(radius), Ac=(angular velocity^2)(radius) or Vt^2/radius.
    3. I computed the velocity of the ball leaving the bat: Vt=angular velocity*radius=(2200degree/s*1.3m)=2860 m*degree/s. However, I just do not know where to go from here. Help please!
Draft saved Draft deleted
Similar Threads - Angular Kinematic problem Date
Scattering angle in relativistic kinematics Feb 23, 2018
Energy eigenvalues of spin Hamiltonian Jan 27, 2018
Angular momentum multiple choice question Dec 10, 2017
The addition of 3 spins Nov 14, 2017
