How Does Angular Momentum Around the Center of Mass Work in Particle Systems?
In summary, the first term in the above equation, resembles the angular momentum around CM, and the second term "the angular momentum of CM", i.e.\textbf{L}_O = \textbf{L}_{CM} + \textbf{R}_{CM}\times \textbf{P}
P3X-018
144
When considering a system of particles with respect to a fixed point O, then the total angular momentum around that point can be writtin as
[tex] \textbf{L}_O = \sum_i \textbf{r}_i\times m_i\textbf{v}_i [/tex]
However in my book they add and substract the vektor [itex] \sum_i \textbf{R}_{CM}\times m_i\textbf{v}_i [/itex], which gives,
[tex] \textbf{L}_O = \sum_i (\textbf{r}_i-\textbf{R}_{CM})\times m_i\textbf{v}_i + \sum_i \textbf{R}_{CM}\times m_i\textbf{v}_i[/tex]
It is then stated that the first term in the above equation, resembles the angular momentum around CM, and the second term "the angular momentum of CM", i.e.
[tex] \textbf{L}_O = \textbf{L}_{CM} + \textbf{R}_{CM}\times \textbf{P} [/tex]
I understand the second term, but the first term seems a little confusing. How can the 1st term be considered as the angular momentum around CM? Indeed the vector [itex] \textbf{r}_i -\textbf{R}_{CM} [/itex] points from CM to the particle i, but how about the velocity vector term [itex] \textbf{v}_i [/itex] of particle i in [itex] \textbf{L}_{CM} [/itex], doesn't that need to be the velocity of the particle i relative to the CM, before it can be considered as the angular momentum around CM?
The idea behind this separation is to say that you can break the angular momentum into two parts. Let's use the Earth for our example.
The first part, L_cm, comes from the body orbiting around its pole. The second part comes from the Earth orbitting around the sun. It's nice because the second part means that you can completely separate out the dynamics of most problems into "body rotating around itself" and then "point mass moving around".
I understand the idea behind it. But when you calculate the angular momentum around some point in an inertial frame, then you need the velocity with respect to that frame, right? I.e. the position vector from the origin of the coordinatsystem to the particle cross the velocity of the particle with respect to that point, correct?
But inorder to calculate the angular momentum around CM wouldn't need the velocity of the particle with respect to CM? Because [itex] \textbf{v}_i[/itex] is with respect to the point O. If CM was moving the the velocity with respect to CM wouldn't be [itex] \textbf{v}_i[/itex], which is just the velocity with respect to O.
So have I misunderstood something, and hence my assumptions are incorrect?
Write [tex]R=\sum_i m_i r_i/M,[/tex] and
[tex]v_i(cm)=v_i-V[/tex]. Plug this into your second equation to derive the fact that the first term is indeed what your last sentence requires.
Now that I think about, then the torque around the CM for the particle system, is
[tex] \mathbold{\tau}_{CM} = \sum_i (\textbf{r}_i-\textbf{R}_{CM})\times \textbf{f}_i [/tex]
And the time derivative of the angular momentum around CM is
[tex] \frac{\mathrm{d}\textbf{L}_{CM}}{\mathrm{d}t} = \sum_i( \textbf{v}_i - \textbf{v}_{CM} ) \times \textbf{p}_i + \sum_i(\textbf{r}_i-\textbf{R}_{CM})\times \textbf{f}_i[/tex]
But inorder for the angular momentum theorem to hold, the first term of the above equation most be [itex] \mathbold{0} [/itex], which means that the momentum [itex] \textbf{p}_i [/itex] most be parallel to the velocity of the particle in the CM-frame, [itex] \textbf{v}_i - \textbf{v}_{CM} [/itex]. Therefore [itex] \textbf{p}_i [/itex] most be the momentum of particle in the CM-frame.
However, in the derivation in my first post, the velocity [itex] \textbf{v}_i [/itex] is with respect to the frame of O, so [itex] m_i\textbf{v}_i [/itex] can't be the momentum of particle in the CM-frame, and hence the expression
[tex]\sum_i (\textbf{r}_i-\textbf{R}_{CM})\times m_i\textbf{v}_i[/tex]
can't be called the angular momentum around the CM. Or where do I go wrong?
I agree that they went out of their way to make this derivation obscure! Try this: Substitute:
[tex]\textbf{v}_i = \textbf{v'}_i + \textbf{v}_{CM}[/tex]
Where the primed velocities are with respect to the center of mass frame. Crank it out and you'll find that the terms with the velocity of the CM will cancel.
1. What is angular momentum around the center of mass (CM)?
Angular momentum around the center of mass is a physical quantity that describes the rotational motion of an object. It is defined as the product of an object's moment of inertia and its angular velocity around the center of mass.
2. How is angular momentum around CM different from angular momentum around a fixed axis?
Angular momentum around the center of mass takes into account the object's entire mass distribution and its rotation around the center of mass, while angular momentum around a fixed axis only considers the object's rotation around a single fixed point.
3. What is the conservation of angular momentum around CM?
The conservation of angular momentum around the center of mass states that the total angular momentum of a system remains constant as long as there are no external torques acting on the system. This means that if one part of the system changes its angular momentum, another part must change in the opposite direction to maintain the total angular momentum.
4. How does changing the moment of inertia affect angular momentum around CM?
Increasing the moment of inertia of an object will decrease its angular velocity, resulting in a decrease in angular momentum around the center of mass. On the other hand, decreasing the moment of inertia will increase the angular velocity and therefore increase the angular momentum.
5. Can angular momentum around CM be negative?
Yes, angular momentum around the center of mass can be negative. This indicates that the object is rotating in the opposite direction of its angular velocity vector. However, the magnitude of the angular momentum is still the same as if it were positive.
  • General Math
  • Quantum Physics
