1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Angular momentum help
  1. Oct 16, 2007 #1
    The figure below is of an overhead view of a thin uniform rod of length 0.790 m and mass M rotating horizontally at angular speed 22.0 rad/s about an axis through its center. A particle of mass M/3.00 attached to one end is ejected from the rod and travels along a path that is perpendicular to the rod at the instant of ejection. If the particle's speed vp is 6.00 m/s greater than the speed of the end of the rod just after ejection, what is the value of vp?
    Li=Lf, L=Iw, l=rmv
    3. The attempt at a solution
    - I haven't been able to attempt this problem because I'm having problems setting it up. I'm trying to set up the initial side right now and I am using 1/12ML^2 for the rod, but unsure what to use for the particle since it's inside of the rod. I think I can solve the problem if I can get past this step.
  3. Oct 17, 2007 #2
    Use conservation of angular momentum. The angular momentum of the particle about the center is mvr
Have something to add?
Similar Discussions: Angular momentum help
  1. Angular Momentum Help (Replies: 20)
  2. Angular momentum help! (Replies: 5)
