Angular Momentum of Mass: Understanding the Equations and their Application
In summary: It is only approximation.In summary, in this conversation, the topic of angular momentum was discussed. The equations for angular momentum, L = mvr and L = Iw, were mentioned and it was noted that the linear momentum equation can be used for the linear portion of the motion of a rigid body. The concept of rotation about an axis rather than a point was emphasized and the need for accurate measurements using the moment of inertia was mentioned. However, in this case, an approximation was used to simplify the problem.
Sarah00
64
L = mvr
L = Iw
I did not attend this lesson due to some reasons. I read it from the book but I could not understand it well. I know the linear momentum well. However, in angular momentum, we have two equations I don't know which one is for which.
My Attempt:
Before:
We have only momntum for the mass that is moving..
L = mvr = 1 × 1 × 0.5 = 0.5
After
L = (Iball + Irod) w = w(Iball + 1/12)
That''s all what I could done
Sarah00 said:
L = mvr
L = Iw
My Attempt:
Before:
After
You have the right idea:
Lbefore = Lafter where L is measured relative to the axis of the rod.
It is just a matter of setting up the right side.
Lafter = Lball + Lrod
Can you complete the right side? (hint: you will have an expression in which the only unknown is ##\omega## the angular speed of the ball and rod after collision).
AM
Thanks,
Lrod = Irod * w = w * ML2/12 = w/12
but what about the Lball .. what forumla should I use?? L = mvr or L = Iw (can you help me to distinguish from them)
If L = Iw then what is I ? should it be mr2 ?
Paying more attention to your units should help.
It is good practice to never write numbers without their corresponding units when solving a physics problem.
Thanks but I still don't know how to find angular momentum.
Is it L = mvr or L = Iw
which one to use and when
OK, I solved it . The answer is 5.2
But I don't know when to use L = mvr or L = Iw
Thanks
Thanks
The short answer is to use both. The motion of a rigid body can be expressed as the velocity of the mass centre plus a rotation about that centre.
The linear part contributes the mvr term, while the rotation adds an Iw term.
In many cases, one or other of these turns out to be zero.
Alternatively, you may be able to express the motion of the body (instantaneously) as purely a rotation about some axis. E.g. for a rolling wheel, the instantaneous centre of rotation is the point of contact with the ground. In this case you may know the moment of inertia about that point. Having expressed the motion entirely as that rotation, the linear term vanishes.
Thanks
The equation ##L = I\omega## is always true for a rigid body. The equation ##L = mvr = mr^2\omega## is true only for point masses. For a point mass, L = mvr = ##m(\omega r) r = mr^2\omega = I\omega## So for a point mass rotating about an axis a distance r away, the moment of inertia is mr2. For calculus purposes, one can think of a rigid body as being made up of an infinite number of point masses distributed according to the geometry of the body.
AM
Likes Harikesh_33
Andrew Mason said:
The equation ##L = mvr ## ... is true only for point masses.
That's over-restrictive. You can use mvr for the linear portion of the motion of a rigid body, as I described.
Since it can be used for each mass element of the body, we can write ##L=\int vr.dm=v\int r.dm=vm\hat r##, where r for a mass element is the distance from that element's line of travel to the reference axis, and ##\hat r## is the distance from the mass centre's line of travel to the reference axis.
Edit: and note that one should always think in terms of rotation about an axis, not rotation about a point. Otherwise you might compute the distance wrongly.
If you use L = mvr for anything other than a point mass, how do you define r? If you use the distance of the centre of mass to the axis of rotation (of the rod), it is only approximate. In the case here, we are approximating the 50 g. mass as a point mass and use L = mvr. Although that is what the student is expected to assume here, it really isn't a point mass.
If you want to be accurate you have to use the moment of inertia of the 50g mass, ie. L = ##I\omega## not L = mvr. This would involve determining the moment of inertia of the 50 g body about the axis through its centre of mass and parallel to the axis of rotation of the rod and then using the parallel axis theorem (to determine the moment of inertia about the axis of rotation of the rod). Obviously that is not what is expected here so we just approximate it using L = mvr and assume it is a point mass.
Your note about rotation about an axis is well taken. I have edited my earlier post.
AM
As I wrote, it should be the distance from the (instantaneous) line of travel of the mass centre to the reference axis (not necessarily the axis of rotation). This is not an approximation, as I thought I showed with my integrals.
A useful application of this is for the standard question about a bowling ball which is initially sliding, not rotating. Taking moments about an axis on the ground, the initial angular momentum is mvr. When rolling, it is ##mv_fr+\frac 25 mr^2\frac {v_f}r=\frac 75 mv_fr##. Since friction has no moment about that axis, the initial and final are equal, yielding the final speed very neatly.
The initial angular momentum is mvr. But if it collides with and sticks onto a rod and starts rotating about an axis through the middle of the rod (as in this problem), you cannot ignore how that the mass is distributed and just treat it as a point mass. In this case we approximate the mass as a point mass and ignore the way it is distributed.
AM
AM
What distribution are you referring to?
AM
If a rigid body is rotating about a point other than its mass centre it is always valid to treat that as the sum of a rotation about its mass centre and the linear motion of its mass centre. You can apply mvr to the linear part, Iw to the rotational motion, and sum the two. This is entirely equivalent to using the parallel axis theorem.
But in this case, after the collision there is no longer any linear motion. The body is stuck on the rod and is rotating about the axis through the geometric centre of the rod. In that case, you have to use the moment of inertia to find the angular speed: ##L_{initial} = m_{obj}vr = L_{final} = \omega({I_{obj}} + I_{rod}) ##
My only point is that the moment of inertia of 50g object is not exactly mr2, although for this problem that is a good approximation. I depends on how that mass is distributed.
AM
AM
I feel you are not reading my posts carefully.
The motion of the ball after sticking to the rod is a rotation about the rod's centre, not a rotation about its own centre.
We can think of this as purely a rotation about the rod's centre, or we can think of its instantaneous motion as a linear (tangential) motion plus a rotation about the ball's centre. With the first option, we use the I given by the parallel axis theorem (I assume that is what you intended in your equation above); in the second, we use the I for rotation about the mass centre and add mvr.
Since ##mv_{final}r=mr^2\omega##, the two methods are completely equivalent.
Actually, it is a combination. The ball (ie. the 50 g. mass) is rotating about an axis through its own centre of mass at the same angular speed as its centre of mass is rotating about the axis of rotation of the rod.
So it seems you agree that one needs to know the distribution of mass within the ball to make it exact (i.e. we have to know I for rotation about the mass centre). That was my point.
AM
AM
Of course I agree. It's consistent with what I have said in every post on this thread. Our dispute began (posts #9 and #10) when you objected to my using mvr for the linear portion of motion of a rigid body.
I am referring to the dimensions and shape of the 50 g object that collides with the rod: for example, the mass might be a spherical ball of a some radius and of uniform density.
AM
?? I was not objecting to using L = mvr for the angular momentum of a non-rotating rigid body moving in a straight line (such as the 50g object before it collides with the rod, relative to the axis through the centre of the rod). I was objecting to using L = mvr to determine the angular momentum of the body when it is rotating about any axis, such as the axis through the centre of the rod. I merely said that "The equation L=mvr (for a rigid body rotating about an axis such this 50 g mass rotating about an axis through the centre of the rod) ... is true only for point masses.". You said that statement was "over-restrictive"...
AM
AM
Ah, but unfortunately that is not what you wrote. The text was simply "The equation L=mvr is true only for point masses", and that is over-restrictive.
At no point did I suggest it could be used to cover the rotational aspect as well.
I just wanted to explain to the OP that when you have a rotating rigid body, you have to use ##L = I\omega## not L = mvr. e.g.: from http://www.cliffsnotes.com/sciences/physics/classical-mechanics/rotational-motion-of-a-rigid-body: "For a rigid body, the angular momentum (L) is the product of the moment of inertia and the angular velocity: L = Iω. For a point of mass, angular momentum can be expressed as the product of linear momentum and the radius ( r): L = mvr."
AM
AM
Ok, but that still is not exactly right. If the axis of rotation is not the mass centre of the body then you have the option of representing the motion as the sum of the linear motion of the mass centre, using mvr for that, and a rotation about the mass centre, using ##I\omega## for that.
... which is exactly equivalent to using ##L = I\omega## where I is the moment of inertia about the axis of rotation...
AM
AM
Which is why I said it was an option.
1. What is angular momentum of mass?
Angular momentum of mass is a physical quantity that describes the rotational motion of an object around an axis. It is the product of the mass of the object, its velocity, and the distance from the axis of rotation.
2. How is angular momentum of mass different from linear momentum?
Angular momentum of mass is a vector quantity that takes into account the direction of rotation, while linear momentum is a vector quantity that only considers the linear motion of an object in a straight line.
3. What factors affect the angular momentum of mass?
The angular momentum of mass is affected by the mass of the object, its velocity, and the distance from the axis of rotation. Additionally, the direction of rotation and any external forces acting on the object can also affect its angular momentum.
4. What is the conservation law related to angular momentum of mass?
The conservation of angular momentum states that the total angular momentum of a system remains constant as long as there are no external torques acting on the system. In other words, angular momentum is conserved in a closed system.
5. How is angular momentum of mass used in real-world applications?
Angular momentum of mass is used in various fields, including physics, engineering, and astronomy. It is utilized in the design of machines and vehicles that involve rotational motion, such as turbines and propellers. It is also used in understanding the motion of celestial bodies, such as planets and stars.
