Homework Help: Angular momentum problem
  1. Nov 22, 2005 #1
    The problem:
    A projectile of mass m=1.8 kg moves to the right with speed v=24.8 m/s. THe projectile strikes and sticks to the end of a stationary rod of mass M=6.75 kg and length d=1.71 m that is pivoted about a frictionless axle through its center. Find the angular speed of the system right after the collision.
    I know the I of a thin rod pivoting about its center is 1/12 Md^2 and that angular momentum is mrv. So with that, I tried this:
    [tex]I_{i}\omega_{i}=I_{f}\omega_{f}[/tex]
    [tex]rmv=\frac{1}{12}\left(m+M\right)d^{2}\omega_{f}[/tex]
    [tex]\omega_{f}=\frac{12rmv}{\left(m+M\right)d^{2}}[/tex]
    [tex]\omega_{f}=\frac{12\left(\frac{1.71m}{2}\right)\left(1.8kg\right)\left(24.8\frac{m}{s}\right)}{\left(1.8kg+6.75kg\right)1.71m^{2}}[/tex]
    [tex]\omega_{f}=18.319\frac{rad}{s}[/tex]
    Wrong answer. Any thoughts? Thanks in advance!
  3. Nov 23, 2005 #2
    Fermat
    error is in the 2nd line, where you have taken the inertia as being for a mass of (m+M) rotating about the rod axle.
    You should have the sum of two separate momenta here, one for M rotating about the rod axle and the other for a point mass, m, rotating about the rod axle, at a distance d/2, with the the same angular velocity.
  4. Nov 23, 2005 #3
    Awesome, got it. Thanks a million for your help! :smile:
Loading...
Similar Threads for Angular momentum problem Date
Angular momentum and a summersault problem Mar 5, 2018
Problem with torque, angular momentum and forces Jun 19, 2017
Angular momentum of a bullet problem Dec 18, 2016
Angular Momentum Problem Dec 7, 2016
