• Support PF! Buy your school textbooks, materials and every day products Here!
Angular Momentum Question?
  • Thread starter math_head7
Angular Momentum Question???
Figure 11-45 (attached) shows a rigid structure consisting of a circular hoop of radius R and mass m, and a square made of four thin bars, each of length R and mass m. The rigid structure rotates at a constant speed about a vertical axis, with a period of rotation of 2.5s. Assuming R=0.50m and m=
2.0kg, calculate (a) the structure's rotational inertia about the axis of rotation and (b) its angular momentum about that axis.
I=[tex]\int[/tex]r2dm
L=I[tex]\omega[/tex]
(a) I did mr2 = (10)(.5)2 = 2.5 (the answer is supposed to be 1.6
Then I tried msrs2 + mcrc2 = (8)(.25)2 + (2)(.5)2 = 1.5 (still incorrect)
(b) Due to not being able to solve "a" I could not began my attempt on "b"
Answers and Replies
Doc Al
Mentor
44,865
1,111
Not sure what you're doing here. The thin rods and the hoop are standard shapes--you can look up their rotational inertia. (You'll need to use the parallel axis theorem.)
first find I of hoop along any diameter using perpendicular axis theorem and then use parallel axis theorem to find I along axis of rotation
do same for square
then just simply add their I
Thanks. I got it.
Related Threads for: Angular Momentum Question?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
