Is Angular Momentum Conserved About Point O?
In summary, angular momentum is a measure of an object's rotational motion, calculated by multiplying its moment of inertia and angular velocity. The conservation of angular momentum states that it remains constant in an isolated system, unless acted upon by an external torque. Torque is the rate of change of angular momentum, meaning that it can cause a change in an object's angular momentum. Real-life examples of angular momentum include the spinning of a top, rotation of a bicycle wheel, and motion of planets around the sun.
princejan7
93
http://postimg.org/image/qghh7y1vr/
can someone explain why angular momentum is conserved about O?
M(P) = d/dt (h(P)) + v(P) x mv(G)
h(P) = I(G)w + r(G/P) x mv(G)
edit: nvm, I got it
... without looking: because that's the Law.
<looking>
What makes you think it might not be?
1. What is angular momentum?
Angular momentum is a measure of an object's rotational motion. It is defined as the product of an object's moment of inertia and its angular velocity.
2. How is angular momentum calculated?
Angular momentum is calculated using the equation L = Iω, where L is angular momentum, I is moment of inertia, and ω is angular velocity.
3. What is the conservation of angular momentum?
The conservation of angular momentum states that the total angular momentum of an isolated system remains constant, unless acted upon by an external torque.
4. How does angular momentum relate to torque?
Torque is the rate of change of angular momentum. This means that an external torque acting on an object will cause a change in its angular momentum.
5. What are some real-life examples of angular momentum?
Some examples of angular momentum in everyday life include the spinning of a top, the rotation of a bicycle wheel, and the motion of a planet around the sun.
