1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Angular Momentum
  1. Nov 21, 2005 #1
    A 2.6 kg particle that is moving horizontally over a floor with velocity (-3.00 m/s)j undergoes a totally inelastic collision with a 4.00 kg particle that is moving horizontally over the floor with velocity (4.20 m/s)i. The collision occurs at xy coordinates (-0.50 m, -0.10 m). After the collision, what is the angular momentum of the stuck-together particles with respect to the origin using vector notation?
    I first tried using conservation of momentum, which gives me 9 as the x-momentum. This is wrong. I know that angular momentum (L) = Iw, but I'm not sure how to calculate I or w.
    I'm also stuck on a similar problem:
    At the instant the displacement of a 2.00 kg object relative to the origin is d = (2.00 m)i + (4.00 m)j - (3.00 m)k, its velocity is v = - (6.40 m/s)i + (2.90 m/s)j + (2.70 m/s)k, and it is subject to a force F = (6.40 N)i - (7.80 N)j + (4.10 N)k. Find the angular momentum of the object and the torque acting on the object about the origin using vector notation.
    To find momentum, I again didn't know how to find Iw, so I just tried multiplying the given mass times the velocity vector. I'm guessing this is wrong because thats for linear momentum.
    Any help would greatly be appreciated!
  3. Nov 22, 2005 #2
    Fermat
    The angular momentum of a particle about an origin is given by,
    L = rp
    where r is position vector of the particle and p is the linear momentum
  4. Nov 22, 2005 #3
    how do you determine which way the velocity of stuck-together particles are going? would i just use pythagorean theorem to find the hypotenuse of the 4.2 velocity and the -3 velocity? and from there, how do i figure out which way the momentum is going? how can there be momentum in the 'k' (vector notation) direction?
  5. Nov 22, 2005 #4
    NateTG
    You need to specify (and keep track of) the direction of the velocity and momentum.
    For particles you can calculate the angular momentum as:
    [tex]\vec{L}=\vec{r} \times \vec{p}[/tex]
    where [itex]\times[/itex] is the cross product, [itex]\vec{r}[/itex] is the vector from the axis of rotation, and [itex]\vec{p}[/itex] is the momentum of the particle.
    The magnitude of [itex]\vec{L}[/itex] will be equal to
    [tex]|r p \sin \theta|[/tex]
    Where [itex]\theta[/itex] is the angle between [itex]\vec{r}[/itex] and [itex]\vec{p}[/itex].
    For forces that apply at a single point, torque can be calculated by
    [tex]\vec{\tau}=\vec{r} \times \vec{F}[/tex]
  6. Nov 22, 2005 #5
    how do i determine r? it isn't just the displacement from the origin, right? because that doesnt work
  7. Nov 22, 2005 #6
    Doc Al
    Staff: Mentor
    Sure it works. (Use the coordinates of the collision to figure out the perpendicular distance between the momentum vectors and the origin.)
  8. Nov 22, 2005 #7
    sorry i was referring to the second problem. but on the first problem, how do i know how fast the stuck-together objects are going in the x or y directions? would they both be moving -3j down and 4.2i across? if so, would i determine the angular momentum in the j direction by doing
    (-.5)(2.6 kg)(-3.00 m/s) = 3.9 kg*m^2/s?
  9. Nov 22, 2005 #8
    Doc Al
    Staff: Mentor
    For the first problem, realize that angular momentum is conserved during the collision. (Find the total angular momentum of the particles before the collision.)
    For the second problem, calculate [itex]\vec{L}=\vec{r} \times \vec{p}[/itex]. (I assume you know how to take the cross product of vectors in cartesian coordinates.)
  10. Nov 25, 2005 #9
    i.. actually don't know how to take the cross product of vectors in cartesian coordinates :( but anyhow, after i find the angular momentum, how do i figure out which direction it's going? because i have to give the angular momentum in vector notation.
  11. Nov 28, 2005 #10
    Doc Al
    Staff: Mentor
Have something to add?
Similar Discussions: Angular Momentum
  1. Angular momentume (Replies: 7)
  2. Angular momentum (Replies: 1)
Loading...
