What is the angular velocity of the bar after being struck by the ball?
In summary, the problem involves a metal bar being struck by a ball and the question is to find the angular speed of the bar after the collision. The methodology involves using the conservation of angular momentum and calculating the angular momentum of the ball before and after the collision, and then setting it equal to the angular momentum of the bar. The weight of the bar is necessary to calculate its mass.
trajan22
134
Hi i have a question with this problem
A thin, uniform, metal bar, 2.00 m long and weighing 90.0 N, is hanging vertically from the ceiling by a frictionless pivot. Suddenly it is struck 1.50 m below the ceiling by a small 3.00-kg ball, initially traveling horizontally at 10.0 m/s. The ball rebounds in the opposite direction with a speed of 6.00 m/s.
Find the angular speed of the bar just after the collision.
I understand that angular momentum is conserved.
what i have done is found the moment of inertia of the bar and the ball
I_bar=(1/3)ml^2
I_ball=m1.5^2
i then added the 2 together to get the total moment of inertia
I_bar+I_ball=I
i then know that the angular momentum is equal to I(w)_init=I(w)_f
therefore
w=(mvl)/I
which means angular velocity is equal to the massof the ball times the velocity (im am not sure which velocity i should use though, should i use both ?)times the distance from the pivot point. all this over I
is this methodology correct?
The ball and the bar are not moving with the same angular velocity at any time. There is no ball contribution to I. You can still compute the total angular momentum of the system before and after collision. Just calculate the angular momentum of the ball about the pivot point before and after the collision, and require that the total angular momentum (bar plus ball) be conserved.
hmm, I am not quite sure i understand exactly what you are saying. because before the collision the angular momentum of both the bar and ball would be 0 since it does not state that the ball is spinning. sorry I am a little confused on what you mean
Angular momentum does not always involve spinning. What is the definition of angular momentum, and I do not mean the equation for rotating objects that is derived from the definition?
I need to leave, so here is a bit more information. If there is angular momentum after the colision, then there had to be angular momentum before the collision. The rod has none, so it must have been the angular mometum of the ball. The definition is
L = r x p
This is a vector equation with the cross product. Find the angular momentum of the ball relative to the pivot point of the rod before and after the collision.
ok so then L(before collision)=m10(1.5) and L(after collision)=m(6)(1.5)?
For the ball, yes, except that you have left out one very important detail, and you have not written the units.
oh right the units agree and would be
L(before collision)=m(kg)*10(m/s)*1.5(m)
L(after collision)=m(kg)*6(m/s)*1.5(m)
so then how can i relate this to the angular momentum of the bar
would i add these together because they act in the same direction and then set them equal to the angular momentum of the door.
hence
L(beforecollision)+L(aftercollision)=L(of bar)
hence
Actually it is
L_ball(beforecollision) + 0 = L_ball(aftercollision) + L(of bar) because the bar is initially at rest. But you must be careful of the signs when you do the calculation. What is the ball doing after the collision?
the ball bounced and is now traveling in the opposite direction therefore the angular momentum would be negative
L_ball(beforecollision) + 0 = -L_ball(aftercollision)+L(of bar)
trajan22 said:
the ball bounced and is now traveling in the opposite direction therefore the angular momentum would be negative <== yes
L_ball(beforecollision) + 0 = -L_ball(aftercollision)+L(of bar) <== No
I know what you mean, but the negative of a negative is a positive. The numerical value of the first term on the right has to be negative. If you put the - sign in front, and the term represented by the words is negative, you wind up with a positive. If you take the initial angular mometum of the ball as positive the left side is positive and the last term is positive.
oh i get what your saying, sorry that's what it was meant to signify. one last question it gives me the weight of the door in Newtons however i don't think that this is needed so do i just solve for the mass.
i guess what i am trying to say is the weight is unnecessary for the problem right?
and thanks for all your help
Are you by any chance confusing this with a similar problem? What door? You do need the mass of the bar in this problem, and you can get that from the weight.
yes i am sorry i meant to say bar, for some reason I've been using door all morning. haha
well thanks so much for your help
1. What is angular momentum and how is it related to a ball?
Angular momentum is a measure of an object's rotational motion. In the case of a ball, it is the measure of how much the ball is spinning. This is important because the angular momentum of a ball can determine its trajectory and stability in motion.
2. How is angular momentum calculated for a ball?
Angular momentum can be calculated by multiplying the ball's moment of inertia (a measure of its resistance to rotation) by its angular velocity (how fast it is spinning).
3. What factors affect the angular momentum of a ball?
The angular momentum of a ball can be affected by its mass, shape, and distribution of mass. A heavier ball will have a higher angular momentum, as will a ball with more mass concentrated towards its outer edges.
4. Can the angular momentum of a ball change?
Yes, the angular momentum of a ball can change if there is an external torque acting on it. This can occur if the ball is hit by an external force, such as a bat or racket, causing it to rotate at a different speed or direction.
5. How is angular momentum conserved for a ball?
According to the law of conservation of angular momentum, the total angular momentum of a closed system (such as a ball in motion) remains constant. This means that if no external torques act on the ball, its angular momentum will remain the same throughout its motion.
9K
