- 20
Hi! Please, could someone tell me who defined angular momentum as r x P? Thank you.
Peter57
Peter57
Newton used it and no one came before Newton.Hi! Please, could someone tell me who defined angular momentum as r x P? Thank you.
Peter57
Sorry, not me. This is a weird question. What is it that you actually want to know ?
It looks like my knowledge of the history of physics turned out to be somewhat useful after all. Before Newton and Galileo, the most commonly believed theory of physics was that of Aristotle and his followers. According to Aristotelian physics, the rest is the natural state and it requires a momentum in order to move an object. The concept of angular momentum came from this context, and the Aristotelian theory stated that it required a constant effort to keep an object in uniform circular motion.
Wait, why do you think this definition is incorrect? It works remarkably well and leads to all manner of useful and accurate predictions.
The originator of [itex]\vec l = \vec r \times \vec p[/itex]? It certainly was not Aristotle, Galileo, or Newton. The modern concept of vectors (and the cross product) was not "invented" until the mid 1800s.
Could you please describe the experiment to us so that we can help you clear any confusions?I found an experiment where r x p is not conserved when, clearly, no external torque acts on the object.
that is what i used to think, and it would explain why angular velocity increases when the radius is smaller but it seems it is proportional to r^2 (mrv) so velocity increases too (angular velocity increases with 1/mr^2, being r^2 the moment of inertia). this is why it needs energy. if you have Serway's book (physics for scientists and engeneers) check out example 11.8 page 347).
Second try: Newton's second law is not violated. You have to apply a force to pull the object in, and that force accelerates the object. That's why it has a greater velocity (not just angular velocity) after you pull it in.
But I think Daniel already knows that. The question is why do you have to increase the tangential velocity when you pull it in, that is, what's up with this whole "angular momentum" conservation thing? Let's see if I can help now.
When the object is spinning around a circle, it constantly "wants" to keep going in a straight line, and the force that holds it on a circular path keeps pulling it in, always constantly bending its trajectory into a circle. The tighter the circle, the more its preferred straight path has to be bent, so the harder we have to pull to keep it going in a circle.
For this reason, if you want to make a tighter circle you have to pull harder. When you pull it in, you are doing work (applying a force over a distance), so you must be speeding the object up, increasing its linear momentum as well as angular momentum.
Helpful?
I'm afraid I disagree with you there. I also must warn you that according to the PF guidelines the discussion of theories which contradict mainstream beliefs is prohibited.I know physics textbooks teach angular momentum is mr^2w, but that is incorrect. For a point mass it is mrw. I wrote a paper on this subject, and a physics journal is now considering its publication.
Global Guidelines said:Overly Speculative Posts:
One of the main goals of PF is to help students learn the current status of physics as practised by the scientific community; accordingly, Physicsforums.com strives to maintain high standards of academic integrity. There are many open questions in physics, and we welcome discussion on those subjects provided the discussion remains intellectually sound. It is against our Posting Guidelines to discuss, in most of the PF forums, new or non-mainstream theories or ideas that have not been published in professional peer-reviewed journals or are not part of current professional scientific discussion. Posts deleted under this rule will be accompanied by a private message from a Staff member, with an invitation to resubmit the post in accordance with our Independent Research Guidelines. Poorly formulated personal theories, unfounded challenges of mainstream science, and overt crackpottery will not be tolerated anywhere on the site.
You haven't upset me in the slightest, I was simply making you aware that such discussions in this forum are prohibited.I am sorry to upset you, but I found an experiment that shows the currently accepted definition of angular momentum r x p is incorrect.
I tend to agree with you there. As such PF has an https://www.physicsforums.com/forumdisplay.php?f=146".Anyway, I understand that, in physics, the experimental truth has the last word, and that should not be suppressed.
The math before vector calculus was a bit convoluted. The concepts we use today existed nonetheless. In particular conservation of angular momentum is quite valid and predates this modern notation. Please explain your experiment.
Edited to add:
Remember that "Extraordinary claims require extraordinary proof".
Perhaps if you explained the problem/experiment you are working on, we can help you understand the issue. Who originated this concept doesn't have anything to do with whether or no it is valid...
We will be more than happy to consider your paper for discussion in our independent research forum, but until then we must insist that you not discuss it in the general physics sections of PF. We don't want to confuse people who come here to learn about what physics is today.I know physics textbooks teach angular momentum is mr^2w, but that is incorrect. For a point mass it is mrw. I wrote a paper on this subject, and a physics journal is now considering its publication.
Don't forget to let us know the name of the journal that has published this.
I am sorry to upset you, but I found an experiment that shows the currently accepted definition of angular momentum r x p is incorrect. That is why I was interested in knowing who defined angular momentum as r x p and why. Unfortunately, I have been unable to do it, so far at least. Anyway, I understand that, in physics, the experimental truth has the last word, and that should not be suppressed.
