Angular momentum
  • Thread starter Oerg
A point particle moves in space under the influence of a force derivable from a
generalized potential of the form
U(r,r&) = V(r) + σ ⋅L
where r is the radius vector from a fixed point, L is the angular momentum about
that point and σ is a fixed vector in space.
Deduce the generalized force Q = (Qr, Qθ, Qφ ) in spherical polar coordinates.
Hence derive Lagrange’s equations of motion.
I actually have the solution to this question, but I do not really understand part of the solution. This is the part that I do not understand from the solution:
Let the polar axis of the polar spherical coordinates (r, θ, ϕ) be in the direction
of σ. Note that [tex] L =(0, - mrv_\phi,mrv_\theta) [/tex], where m is the mass of the particle.
[tex]U(r, v) = V (r) + \sigma \cdot \vec{L} [/tex]
[tex]= V (r) + \sigma ( L_r \cos \theta - L_\theta \sin \theta ) [/tex]
[tex]= V (r) + \sigma mv_\phi r \sin \theta[/tex]
Firstly, [tex] L_r [/tex] is zero? I have difficulty visualizing [tex] L_r [/tex].
Why is there a negative in front of [tex] mrv_\phi [/tex]?
Which is the polar axis for spherical coordinates?
It would be good if someone could provide a link or explain how to visualize [tex] L_r , L_\theta[/tex] and [tex] L_\phi[/tex].
Any help would be appreciated, thanks.
Answers and Replies
(1) [itex]L_r[/itex] is not zero, but the [itex]\theta[/itex] component of [itex]\sigma[/itex] is zero, that's why that term disappears.
(2) Through geometry and trigonometry you should be able to see that [itex]L_\theta[/itex] is negative.
(3) I've always defined [itex]\phi[/itex] to be the polar angle (the one that sweeps the x-y plane), but mathematicians do it oppositely and call [itex]\theta[/itex] to be this angle. It seems this problem follows what I use (that is, [itex]\phi[/itex] is your polar angle).
(4) http://quantummechanics.ucsd.edu/ph130a/130_notes/node216.html" [Broken] is pretty good at giving the geometry of angular momentum in spherical coordinates (from Cartesian coordinates). In the figure they give, magenta is [itex]L_\theta[/itex], blue is [itex]L_r[/itex] and green is [itex]L_\phi[/itex]
gabbagabbahey
Really?...Remember, [itex]L_r\equiv \textbf{L}\cdot\mathbf{\hat{r}}=(\textbf{r}\times\textbf{p})\cdot\mathbf{\hat{r}}[/itex], and by definition of the cross product, [itex]\textbf{r}\times\textbf{p}[/itex] must be perpendicular to [itex]\textbf{r}[/itex].
I disagree. To me, it looks like [itex]\theta[/itex] is the polar angle here.
@Oerg... To more directly answer you question, the polar axis is usually taken to be the z-axis. So, "choosing [itex]\mathbf{\sigma}[/itex] to be directed along the polar axis" is the same as choosing your coordinate system so that the z-axis is aligned with [itex]\mathbf{\sigma}[/itex]
I don't really understand.
So [tex] \sigma [/tex] is also in spherical coordinates, then it must have a [tex] \sigma_r [/tex] component?
Also, the r coordinate in spherical coordinates is scalar and represents the magnitude? If it is then [tex] L_r [/tex] should be non-zero if the angular momentum is non zero and the dot product with [tex] \sigma[/tex] should also produce a non-zero r coordinate component?
Ahh, I think I might have got it.
If I do the product in cartesian coordinates, then sigma is aligned to the z component of the angular momentum and the z component of the angular momentum is the angular momentum associated with the rotation in the x-y plane which has an angle of [tex] \phi [/tex]. The answer that I get will be the same as the solution,
but my questions still remain. Also, is the dot product for spherical coordinates different from the dot product in cartesian coordinates?
Related Threads on Angular momentum
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
