Calculating Angular Momentum of an Aircraft Near Pittsburgh
Pittsburgh.In summary, an aircraft of mass 10,000 kg flying at an altitude of 3000 m and a speed of 300 km/h is 100 km northwest of Pittsburgh. When calculating its angular momentum about Pittsburgh, the distance of 100 km should be converted to meters and the velocity of 300 km/h should be converted to m/s. The radial component of velocity does not contribute to the angular momentum.
tony873004
143
An aircraft of mass 10,000 kg is 100 km northwest of Pittsburgh at an altitude of 3000 m flying due east at 300 km/h. What is its angular momentum about Pittsburgh?
L=rp sin theta
for r, would I use 100 km (converted to m)
Or the closest approach to pittsburgh, which would be cos(45*300km/h)
For velocity in computing p, would I use 300 km/h (converted to m/s) or only its radial component to pittsburgh which is 300 / sin 45
There are lots of ways to approach this. You just have to be consistent. r*sin theta should be the same wherever you calculate it. The radial component of p would not contribute to the angular momentum
In this scenario, the angular momentum of the aircraft about Pittsburgh can be calculated using the formula L = rp sin theta, where r is the distance from Pittsburgh to the aircraft, p is the linear momentum of the aircraft, and theta is the angle between the r vector and the p vector.
For the distance component, we would use the closest approach to Pittsburgh, which is 100 km (converted to 100,000 m). This is because the angular momentum is measured from the point of reference, which in this case is Pittsburgh.
For the velocity component, we would use the radial component of the aircraft's velocity, which is 300 km/h (converted to 83.33 m/s). This is because the angular momentum is a vector quantity and only the component of velocity in the direction of the r vector is considered.
Using these values, we can calculate the angular momentum of the aircraft about Pittsburgh as:
L = (100,000 m) * (10,000 kg) * (83.33 m/s) * sin(90°)
= 8.33 x 10^11 kg*m^2/s
Therefore, the angular momentum of the aircraft about Pittsburgh is 8.33 x 10^11 kg*m^2/s. This value represents the rotational motion of the aircraft around Pittsburgh, taking into account its mass, distance, and velocity.
1. What is angular momentum?
Angular momentum is a physical quantity that describes the rotational motion of an object. It is a vector quantity that depends on the mass, velocity, and distance from the axis of rotation of the object.
2. How is angular momentum calculated?
Angular momentum is calculated by multiplying the moment of inertia (a measure of an object's resistance to rotational motion) by the angular velocity (the rate of change of the angle of rotation) of the object.
3. What are the units of angular momentum?
The units of angular momentum are kilogram meters squared per second (kg·m²/s) in the International System of Units (SI).
4. What is the conservation of angular momentum?
The conservation of angular momentum states that the total angular momentum of a system remains constant, as long as there are no external torques acting on the system. This means that angular momentum cannot be created or destroyed, only transferred between objects.
5. How does angular momentum differ from linear momentum?
Angular momentum and linear momentum are both important physical quantities in describing motion, but they differ in their direction and application. Linear momentum is a measure of an object's motion in a straight line, while angular momentum is a measure of an object's rotation around an axis. They also have different units, with linear momentum measured in kilogram meters per second (kg·m/s) and angular momentum measured in kilogram meters squared per second (kg·m²/s).
