Solving Angular Rotation Homework: Question b, c & d
In summary, the problem involves a 1kg engine rotating at 1 rad/sec around a point on a 3 meter wire. The engine produces an acceleration of 1 rad/sec^2 and is fired for 2 minutes. The goal is to find the final angular speed after 2 minutes, the tension in the wire, the distance traveled by the engine while accelerating, and the kinetic energy of the engine after it shuts down. To find the final angular speed, we can use the equation \omega = \omega _i + \alpha t, where \alpha is the constant angular acceleration. To find the tension in the wire, we can use the final angular speed and calculate the centripetal force. To find the distance traveled
ataglance05
43
A 1kg engine rotates at 1 rad/sec about a point on a 3meter wire. The engine produces an acceleration of 1 rad/sec^2 and is fird for 2 minutes.
a) What is the ω at the end of 2 minutes?
b) what's the tension in the wire at the end of 2 min.?
c) how far will the engine travel in meters while it's accelerating?
d) what's the Kinetic Energy of the engine after it shuts down?
a)ω=radius/Time or ω= θ/Time
B) ?
c) S=rθ
θ= ωi(T)+1/2αT^2
d) KE=1/2(Ι)(angluar acceleration)(T)^2
Ι=1/2mr^2
a) ω=radius/Time
ω=3/120= 0.25 rad/sec
b)?
c) ?
d) Ι=1/2mr^2
Ι=1/2(1)(3)^2= 3
KE=1/2(3)(1)(120)^2
KE=21600 J
need help with b&c and with corroborating a&d!
thanks!
a) The engine is experiencing a constant angular acceleration, [tex]\alpha[/tex], while it is fired. The constant angular acceleration equations look similar to the constant linear acceleration equations:
[tex]\omega = \omega _i + \alpha t[/tex]
b) Use the final angular speed to calculate the centripetal force that the engine is experiencing, this will be the tension in the wire.
c) your equations should do the trick
d) I think the kinetic energy is given by
[tex]EK = \frac{1}{2}I \omega ^2[/tex]
b) To find the tension in the wire, we can use the formula T=mrα, where T is the tension, m is the mass of the engine (1kg), r is the radius of rotation (3m), and α is the angular acceleration (1 rad/sec^2). Plugging in these values, we get T=1(3)(1)=3N. So, the tension in the wire at the end of 2 minutes is 3 Newtons.
c) To find the distance traveled by the engine while it is accelerating, we can use the formula S=rθ, where S is the distance, r is the radius of rotation (3m), and θ is the angular displacement. To find θ, we can use the formula θ= ωi(T)+1/2αT^2, where ωi is the initial angular velocity (1 rad/sec), T is the time (2 minutes = 120 seconds), and α is the angular acceleration (1 rad/sec^2). Plugging in these values, we get θ= (1)(120)+1/2(1)(120)^2= 120+7200= 7320 rad. Now, plugging this value into the first formula, we get S= (3)(7320)= 21960 meters. So, the engine will travel 21960 meters while it is accelerating.
d) To find the kinetic energy of the engine after it shuts down, we can use the formula KE=1/2(Ι)(ω)^2, where Ι is the moment of inertia (1/2mr^2), and ω is the angular velocity (0.25 rad/sec). Plugging in these values, we get KE=1/2(1/2)(1)(3)^2(0.25)^2= 0.09375 J. So, the kinetic energy of the engine after it shuts down is 0.09375 Joules.
1. How do I calculate angular velocity?
The formula for angular velocity is ω = Δθ/Δt, where ω represents angular velocity, Δθ represents the change in angular displacement, and Δt represents the change in time. To solve for angular velocity, simply divide the change in angular displacement by the change in time.
2. What is the difference between angular velocity and linear velocity?
Angular velocity refers to the rate of change of angular displacement, while linear velocity refers to the rate of change of linear displacement. Angular velocity is measured in radians per second, while linear velocity is measured in meters per second.
3. How do I determine the direction of angular velocity?
The direction of angular velocity is determined by the direction in which an object is rotating. If an object is rotating counterclockwise, the angular velocity will be positive. If an object is rotating clockwise, the angular velocity will be negative.
4. What is the difference between angular velocity and angular acceleration?
Angular velocity refers to the rate of change of angular displacement, whereas angular acceleration refers to the rate of change of angular velocity. Angular acceleration is represented by the symbol α and is measured in radians per second squared.
5. How do I use the right hand rule to determine the direction of angular velocity?
The right hand rule is used to determine the direction of angular velocity in a rotating system. To use this rule, point your right thumb in the direction of the axis of rotation and curl your fingers in the direction of the rotating object. The direction your fingers are pointing represents the direction of the angular velocity.
