Angular speed and momentum.
In summary, when you catch a ball moving in the same direction (but faster) on a turntable with frictionless bearings, the angular speed of the turntable increases. Your angular momentum also increases, while the ball's angular momentum decreases. The total angular momentum of the entire system remains the same. This shows that angular momentum is conserved in this system.
sonutulsiani
138
You are standing on the edge of a turntable with frictionless bearings that is initially rotating when you catch a ball that is moving in the same direction (but faster than) you are moving and on a line tangent to the edge of the turntable. Assume you do not move on the turntable.
1. What happens to the angular speed of the turntable during the catch?
A. It increases.
B. It decreases.
C. It remains the same.
2. What happens to your angular momentum during the catch?
A. It increases.
B. It decreases.
3. What happens to the angular momentum of the ball during the catch?
A. It increases.
B. It decreases.
4. What happens to the total angular momentum of the entire system (turntableyou- ball) during the catch?
A. It increases.
B. It decreases.
Please help me with this. Can't figure it out.
Start with the definition of angular momentum:
(1) [tex]\vec L = m \vec v \times \vec r [/tex]
If v is purely tangential as it is here then [itex]\vec L = = m|v|r \hat{n}[/itex]
and this definition of angular velocity:
(2) [tex]\vec \omega r^2 = \vec v \times \vec r[/tex]
You can also use:
(3) [itex]\omega = v_T/r[/itex] where [itex]v_T[/itex] is the tangential speed.
1. is pretty easy. Ask yourself: when I catch the ball, do I speed up, slow down or is there no change? What does that do the angular speed? (Hint: use the above equations. Since r does not change, if tangential speed increases, what happens to [itex]\omega[/itex]?)).
2. What happens to the mass on the turntable when I catch the ball? What happens to [itex]\vec L[/itex] in equation (1) if angular speed changes as you have found in 1. and the mass changes?
3. Is somewhat tricky because the ball has angular momentum before it is caught. Use (1) to determine what that is. What happens to the ball's speed? How does that affect L in equation (1)?
4. This is the most important question. Can you show that angular momentum is conserved?
AM
1. It's increasing
2. Since angular speed increases, angular momentum also increases?
3. I didn't get it. If the ball has momentum before, so it should increase?
4. It's same
sonutulsiani said:
1. It's increasing
Why the question? Since L = mvr, what happens to L if v increases?
Does the ball speed up or slow down when it is caught? So what happens to its angular momentum: L = mvr ?
AM
2 is increasing.
And 3 will be decreasing
1. What is angular speed?
Angular speed is a measure of how fast an object is rotating around a fixed point, and is measured in radians per second (rad/s) or revolutions per minute (RPM).
2. How is angular speed related to linear speed?
Angular speed and linear speed are related by the formula v = ω * r, where v is linear speed, ω is angular speed, and r is the distance from the object to the fixed point.
3. What is angular momentum?
Angular momentum is a measure of the amount of rotational motion an object has, and is equal to the product of the object's moment of inertia and its angular speed.
4. How does angular momentum differ from linear momentum?
Angular momentum and linear momentum are both measures of an object's motion, but angular momentum is specific to rotational motion, while linear momentum is specific to linear motion.
5. What factors affect the angular speed and momentum of an object?
The angular speed and momentum of an object can be affected by factors such as the object's moment of inertia, external forces or torques acting on the object, and the conservation of angular momentum.
9K
9K
