• Support PF! Buy your school textbooks, materials and every day products Here!
Angular Speed, Glob and Rod
http://loncapa2.physics.sc.edu/res/msu/physicslib/msuphysicslib/21_Rot3_AngMom_Roll/graphics/prob21a_bar.gif
On a frictionless table, a glob of clay of mass 0.38 kg strikes a bar of mass 0.90 kg perpendicularly at a point 0.55 m from the center of the bar and sticks to it. If the bar is 1.30 m long and the clay is moving at 8.1 m/s before striking the bar, at what angular speed does the bar/clay system rotate about its center of mass after the impact?
[tex]L_i=RXP=I\omega[/tex]
[tex]cm_[new]=\frac{all m*d}{total mass}[/tex]
Parallel Axis Theorem
M is mass of rod and m is mass of glob.
[tex]L_i=RXP=mvb=1.6929[/tex]
[tex]L_f=I_{glob}\omega+I_{rod}\omega[/tex]
[tex]\delta=distance from old cm to new cm[/tex]
[tex]\delta=\frac{mb}{m+M}=.1633 m[/tex]
[tex]I_{glob}=m(b-\delta)^2[/tex]
[tex]I_{rod}=\frac{M(L)^2}{12}+M\delta^2[/tex]
[tex]L_i=L_f[/tex]
I get 8.15 rad/s which is wrong, the right answer is 5.743. What did I do wrong?
Answers and Replies
Doc Al
Mentor
44,912
1,170
This is the angular momentum of the blob about the center of the bar. What you need is the angular momentum about the center of mass of the system--that is the quantity that is conserved.
So I should have [tex]L_i=mv(b-\delta)[/tex] ?
Thanks, I got it.
Related Threads on Angular Speed, Glob and Rod
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
