Angular Speed of Bicycle [SOLVED]
In summary, the problem involves finding the final angular speed of a wheel after a wrench is applied to it for 3.1 seconds with a normal force of 2.7 N and a coefficient of friction of 0.46. The initial angular speed is given as 230 rpm and the mass of the wheel is 1.9 kg concentrated mostly at the rim. By using the equations for torque, moment of inertia, and angular acceleration, the final angular speed is calculated to be 17.962 rad/s.
nightshade123
82
[SOLVED] Angular Speed
[tex]\tau[/tex] = r * F
youve got our bicycle upside-down for repairs with its 66 cm diameter wheel spinning freely at 230 rpm. the mass of the wheel is 1.9 kg and is concentrated mostly at the rim. you hold a
wrench against the tire for 3.1s with a normal force of 2.7 N. if the coefficient of friction between the wrench and the tire is 0.46 what is the FINAL ANGULAR SPEED OF THE WHEEL?
diameter = 66 cm
radius = .033m
mass = 1.9 kg
Norm Force = 2.7 N
friction coef = .46
[tex]\omega[/tex]0 = 230 rpm
[tex]\omega[/tex]0 = 24.1 rad/s
w = ?
eqns
I = Mr^2
[tex]\omega[/tex] = [tex]\omega[/tex]0 + [tex]\alpha[/tex] * t
[tex]\tau[/tex] = r * F * sin(theta)
[tex]\tau[/tex] = I [tex]\alpha[/tex]v=[tex]\omega[/tex] * r
x
where F is the Friction Force
r*F = M * r^2 * [tex]\alpha[/tex]
we can solve for [tex]\alpha[/tex] and it = 19.08
[tex]\omega[/tex] = ( [tex]\omega[/tex]0 + [tex]\alpha[/tex] * t )[tex]\omega[/tex] = 85.48 rad/s
that means it sped up...
idk how to do this problem keep getting confused with the answers I am getting
any help?
thanks in advance for your time and effort.
initial angular speed= 230 rpm.
torque = r * f * sin 90 degrees
>> torque= .33 * .46 * 2.7 ( radius * frictional force)
calculate torque.
Now the big ques is:
What is the moment of inertia of a wheel?
nightshade123 said:
diameter = 66 cm
radius = .033m
You have a typo here that messed you up later. Radius = 0.33m.
x
Perfectly correct, except that you used the wrong value for the radius.
Note that the angular acceleration created by the friction is opposite to the initial angular velocity, so the wheel slows down.
im having trouble interpreting my answer
asuming that is right
then i put it in this eqn to find [tex]\omega[/tex] = 30.238 rad/s
so next i would take [tex]\omega[/tex] - [tex]\omega[/tex]0 to find the change over 3.1 sec?
thus producing an answer of 6.138 rad/s
and then they want to know final angular speed so 24.1 - 6.138 = 17.962 rad/ s^^^^that was the more logical approach ^^^^vvvv you can also say that vvvv
this one just produces the same answer negative, so that's why it doesn't make sense
[tex]\omega[/tex] = 24.1 rad/s
solve for [tex]\omega[/tex]0 and you get -17.962 rad/s, but then you got to change the sign, which u can because it asks for speed
That's the initial angular speed.
As I already pointed out, the acceleration is negative. Done correctly, this will give you the final speed.
The change is just alpha*time. What is your value for alpha?
Seems like you're doing a bit of extra work.
Not sure what you're doing here. Why would you solve for the initial speed? That's given.
[tex] \omega [/tex] will not increase. It will decrease. You have to put a negative sign before [tex]\alpha[/tex] in that equation.
that makes sense! and it produces the 17.962 rad/s instantly! thanks for the help
doc al, since i forgot to change accel to negative i showed how to produce the same answer, but with a lot more work, lol and i was just throwing out that idea for the 2nd part, i knew it didnt make sense but it was worth mentioning.
1. What is Angular Speed of a Bicycle?
Angular speed of a bicycle refers to the rate at which the bicycle's wheels are rotating or spinning in a circular motion. It is measured in radians per second or revolutions per minute.
2. How is Angular Speed of a Bicycle Calculated?
Angular speed of a bicycle can be calculated by dividing the linear speed of the bicycle by the radius of its wheels. It can also be calculated by dividing the angle of rotation of the wheels by the time it takes to complete the rotation.
3. What Factors Affect the Angular Speed of a Bicycle?
The angular speed of a bicycle can be affected by various factors such as the size and weight of the wheels, the gear ratio, the surface on which the bicycle is riding, and any external forces like wind or friction.
4. Why is Angular Speed Important in Cycling?
Angular speed is important in cycling as it determines the speed and efficiency of the bicycle. It also affects the stability and handling of the bicycle, making it crucial for cyclists to maintain an optimal angular speed for a smoother and more controlled ride.
5. How Can Angular Speed of a Bicycle be Altered?
The angular speed of a bicycle can be altered by changing the gear ratio, adjusting the tire pressure, or changing the size of the wheels. Factors like pedaling speed and external forces can also affect the angular speed of a bicycle.
