• Support PF! Buy your school textbooks, materials and every day products Here!
Angular speed
138
1. Homework Statement
The pulley in system drawn below has radius 8.0 cm and mass 0.6 kg. The surface on which the 4.0 kg mass is resting is frictionless. Suppose the 2.0 kg block is released from rest.
http://bcs.whfreeman.com/WebPub/Physics/tiplerphysics6e_bridge/question_bank_images/9-72.png?9954
1. What is the speed of the block in m/s after it falls a distance of 2.5 m. Round your answer to one decimal place. Derive a complete formula for the answer before substituting values to avoid round-off errors. Use g = 9.81 m/s^2.
2. What is the angular speed of the pulley in rad/s at the instant the block reaches a distance of 2.5 m? Round your answer to one decimal place. Derive a complete formula for the answer before substituting values to avoid round-off errors. Use g = 9.81 m/s^2. Round your answer to two significant figures.
2. Homework Equations
3. The Attempt at a Solution
What I did is:
T1=m1a (T1 is tension connecting the 4 kg block, m1 is the mass of 4 kg block)
(T2-T1) = I [tex]\alpha[/tex] ( T2 is tension connecting the 2 kg block, I is the moment of inertia of pulley)
m2g - T2 = m2a (m2 is mass of 2 kg block)
These are the three equations I was able to find but how do I get the answers to these question?
Delphi51
3,407
You have 4 unknowns, so you'll need another equation.
Can you relate "a" and "alpha"? You know the radius . . .
138
at=r alpha?
Delphi51
3,407
Okay, you should have 4 equations and 4 unknowns now, so just a matter of substitution to solve for the one you want.
138
First question asks for speed of the block after 2.5 m
I used the conservation of energy equation. I got mghi = 0.5 mv^2f
So I got vf = 7, is it right?
I still can't figure out the second question..
Delphi51
3,407
mghi = 0.5 mv^2f doesn't include the rotational energy of the pulley.
You'll have to help me - I forget how to find the moment of inertia I for the pulley. It is just a cylinder, so you probably have a formula for it.
For #2, do you have a formula relating the velocity to the angular velocity?
Delphi51
3,407
Okay, so you can find the moment of inertia of the pulley and add its rotational energy term to your equation.
Related Threads for: Angular speed
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
