Anharmonic Pendulum
  1. Aug 1, 2004 #1
    cj
    Suppose I have a simple pendulum whose period was designed to be exactly 2 seconds. I am able to time the period reliably to within 0.03s. What is the smallest amplitude, in degrees, I would need to use before I could see the anharmonic effects in this pendulum?
  3. Aug 1, 2004 #2
    Gokul43201
    Staff Emeritus
    If you are 'seeing' the anharmonic effects only through a measurement of T, I can't see how the amplitude plays any role at all.
    Perhaps, I don't understand exactly what you're trying to do here...
  4. Aug 1, 2004 #3
    cj
    There's a point, beyond which, it won't behave
    harmonically -- rather anharmonically.
    The value of T is related to this.
  5. Aug 2, 2004 #4
    Galileo
    The question is basically when the 'small angle' approximation is no longer valid.
    We can't solve the the differential equation without this approximation:
    [tex]\ddot\theta+\frac{mgl}{I}\sin\theta =0[/tex]
    Where [itex]\theta[/itex] is the angle with the vertical, m is the mass of your pendulum,l is the distance from the center of mass to the axis of rotation and I is the moment of intertia about the axis of rotation.
    When the angle is small, then [itex]\sin\theta\approx \theta[/itex] and we can solve de diferrential equation.
    I think it must be solved numerically. A way to measure when visible anharmonic effects arise is to see when the period of the oscillation is greater than 0.03 s off with the expected value. Don't know how to calculate it though...
  6. Aug 2, 2004 #5
    arildno
    Dearly Missed
    We may go a few steps further, before resorting to numerical means:
    We start with Galileo's equation, and add a couple of initial conditions:
    [tex]\ddot{\theta}+\omega^{2}\sin\theta=0,\theta(0)=\theta_{0},\dot{\theta}(0)=0[/tex]
    We multiply the equation with [tex]\dot{\theta}[/tex] integrate, rearrange, and utilize intitial conditions, and gain:
    [tex]\dot{\theta}=\pm\omega\sqrt{2(\cos\theta-\cos\theta_{0})}[/tex]
    The negative root is used on time intervals where [tex]\theta\to{-\theta_{0}}[/tex]
    (assuming [tex]\theta_{0}>0[/tex])
    We thereby gain:
    [tex]T=\frac{2}{\omega}\int_{-\theta_{0}}^{\theta_{0}}\frac{d\theta}{\sqrt{2(\cos\theta-\cos\theta_{0})}}[/tex]
    In the harmonic case, we have [tex]T_{h}=\frac{2\pi}{\omega}[/tex]
    Hence, given a relative error bound [tex]\epsilon[/tex] we gain the bound of the initial angle as:
    [tex]|1-\frac{1}{\pi}\int_{-\theta_{0}}^{\theta_{0}}\frac{d\theta}{\sqrt{2(\cos\theta-\cos\theta_{0})}}|<\epsilon[/tex]
  7. Aug 3, 2004 #6
    cj
    Thanks very much arildno.
    Question: does the [tex]\epsilon[/tex] in the equation
    specifically refer to the uncertainty (in my case, 0.03)?
  8. Aug 3, 2004 #7
    arildno
    Dearly Missed
    No, it does not!
    [tex]\epsilon[/tex] is the relative error bound, that is:
    [tex]\epsilon=|\frac{(2\pm0.03)-2}{2}|=0.015[/tex]
  9. Aug 3, 2004 #8
    cj
    Got it -- thanks again!
