Annihilation, perhaps a defination problem
  • Thread starter Thread starter Hevonen
    Annihilation
Hevonen
[SOLVED] Annihilation, perhaps a defination problem
Problem:
An electron and an anti-electron undergo mutual annihilation.
Which of the following does not have to be conserved?
A. Electric charge
B. Kinetic energy
C. Lepton number
D. Momentum
Attempt to question:
The answer is B but I why not also d. I would consider that the mass of photon is zero. So in both B and D, kinetic energy and momentum are perhaps zero. Problem is: it is impossible to divide by zero. Therefore, this problem seems to a definatition problem. It must be that momentum conserves but why? What is the assumption in the theory?
Thank you for your answers!
Photons are massles, yes, but they still carry momentum (equal to \hbar k)
E^2 = m^2c^4 + P^2c^2 \qquad so \quad E_{\gamma} = Pc \quad
where \quad E = h \nu = \frac{h c}{\lambda} \qquad so \quad P = \hbar K
where \qquad K= \frac{2\pi}{\lambda}
Whilst the photon is indeed massless* it most certainly has momentum. Consider the expression for relativistic energy,
E^2 = p^2c^2 + m^2c^4
As you correctly say, the photon is massless and hence the final term disappears,
\Rightarrow p = \frac{E}{c}
Hence, the magnitude of the photon's momentum is it's energy divided by the speed of light in a vacuum. Notice that since a photon has no 'rest energy', all it's energy must be kinetic energy.
Returning to your problem, before the collision the total momentum of the system is zero (assuming that both particles are traveling directly towards each other with the same energy). So to conserve momentum two photons are created, traveling in opposite directions with the same energy.
\hline
(*) For those proponents of so-called relativistic mass, let us not get into another discussion regarding the pros and cons of the subject as the concept of relativistic mass is not nesscary to explain the OP's query.
\hline
Thank you!
Your both answers solve this problem: photon is massless and it has momentum due to relativity.
Hevonen said:
Thank you!
Sounds good to me. No problem :smile:
I am not sure if this falls under classical physics or quantum physics or somewhere else (so feel free to put it in the right section), but is there any micro state of the universe one can think of which if evolved under the current laws of nature, inevitably results in outcomes such as a table levitating? That example is just a random one I decided to choose but I'm really asking about any event that would seem like a "miracle" to the ordinary person (i.e. any event that doesn't seem to...
