Solve Annoying Trig Equation for Theta: Linear Solution Using Trig Functions
  • Thread starter ice109
  • Tags
    Trig
In summary, the conversation discussed different approaches to solving the equation \frac{1}{2} = k\cos(\theta) -\sin(\theta), with the goal of making it linear in one of the trigonometric functions. Suggestions included using inverse trigonometric functions, dividing both sides by (k2 + 1)1/2, and introducing a new angle \alpha to simplify the equation.
ice109
1,714
can anyone think of a cute way to solve this for theta or at least make it linear in one of the trig functions?
[tex] \frac{1}{2} = k\cos(\theta) -\sin(\theta)[/tex]
well i think this approach would work-i am not sure though-:
[tex] \frac{1}{2} = k((\cos(\theta) -\sin(\theta)))[/tex]
[tex]\frac{1}{2}=k\cos(\theta)-(\(1-cos(\theta))^{1/2}[/tex], now square both sides, and after some transformations we get:
[tex]\sin(2\theta)=1-\frac{1}{4k^{2}}[/tex]
i think this would do.
Ignore it, i thought k was multiplying the whole thing.><
-(sin-inverse((1-2kcos@)/2)) = @
where @ = theta
or
cos-inverse((1+2sin@)/2K) = @
where @ = theta
i could be wrong though
anyone else?
There should be a chapter in your textbook about solving equation of the form:
a sin(x) + b cos(x) = c.
We can just divide both sides by (k2 + 1)1/2, to get:
[tex] \frac{1}{2\sqrt{k ^ 2 + 1}} = \frac{k}{\sqrt{k ^ 2 + 1}} \cos(\theta) - \frac{1}{\sqrt{k ^ 2 + 1}} \sin(\theta)[/tex]
Now, let angle [tex]\alpha[/tex], be an angle such that:
[tex]\cos \alpha = \frac{k}{\sqrt{k ^ 2 + 1}}[/tex], and [tex]\sin \alpha = \frac{1}{\sqrt{k ^ 2 + 1}}[/tex], such angle does exist, because:
[tex]\sin ^ 2 \alpha + \cos ^ 2 \alpha = \frac{k ^ 2}{k ^ 2 + 1} + \frac{1}{k ^ 2 + 1} = 1[/tex]
Now, your equation will become:
[tex] \frac{1}{2\sqrt{k ^ 2 + 1}} = \cos(\alpha + \theta)[/tex], which is easy to solve. Right? :)
You can do the following:
[tex]\sin=\pm \sqrt{1-\cos^2}[/tex]
so
[tex]\frac{1}{2}=k \cos \theta \pm \sqrt{1 - (\cos \theta)^2}[/tex]
[tex]0=k \cos \theta - \frac{1}{2} \pm \sqrt{1-(\cos \theta)^2}[/tex]
multiply both sides by
[tex](k \cos \theta - \frac{1}{2}) \mp \sqrt {1-(\cos \theta)^2}[/tex]
Which eliminates the square root, and leads to a quadratic in [itex]\cos \theta[/itex]
indeed very cute
1. What is a "trig equation"?
A trig equation is an equation that involves trigonometric functions, such as sine, cosine, and tangent. These functions are used to describe relationships between the sides and angles of a triangle.
2. How do you solve a trig equation for theta?
To solve a trig equation for theta, you can use algebraic methods or trigonometric identities. First, isolate the trig function that contains theta on one side of the equation. Then, use inverse trig functions or trigonometric identities to solve for theta.
3. What is a linear solution for a trig equation?
A linear solution for a trig equation is when the equation can be simplified to a linear equation, which means it has the form y = mx + b. This type of solution makes it easier to find the value of theta.
4. Can you use trig functions to solve any type of trig equation?
Yes, you can use trig functions to solve any type of trig equation, as long as the equation only involves trigonometric functions and does not contain other variables or constants.
5. Why is solving trig equations important?
Solving trig equations is important because it allows us to find the values of unknown angles or sides in a triangle, which is useful in many real-life applications such as navigation, engineering, and physics.
  • Calculus
