How Do You Calculate the Derivative of 1/(x-1) Using the Definition?
  • Thread starter TheKracken
  • Tags
    Derivative
In summary, the process of finding f'(x) for f(x)=1/(x-1) using the definition of a derivative involves substituting f(x+h) into the formula and simplifying to find the limit. This can be done by adding the two fractions in the numerator and using algebra skills to cancel out the h in the denominator.
TheKracken
356
Find f'(x) of f(x)= 1 over x-1
definition of a derivative is
f'(x)= lim as h→ 0 of f(x+h) - f(X) ALL OVER h
I have no idea how to do this using the definition of a derivative...
If [itex]\displaystyle f(x)=\frac{1}{x-1}\,,[/itex] then what is f(x+h) ?
This is where I draw a blank...
is it simpily (1/x-1 +h) - f(x) over h meaning it cancels out to be h/h or 0?
No.
All Sammy asked you was what is f(x + h)?
In the right side of the formula equation, replace x by x + h. That's how function notation works.
is it simply (1/x-1 +h) - f(x) over h meaning it cancels out to be h/h or 0?
Don't forget that f(x) is 1/(x-1), and No, h does not cancel the way you are supposing it does.
You will have:
[itex]\displaystyle\frac{f(x+h)-f(x)}{h}=\frac{\displaystyle\frac{1}{x+h-1}-\frac{1}{x-1}}{h}[/itex]​
You need to add the two fractions in the numerator -- use a common denominator.
After some simplification, you will get the h in the overall denominator to cancel.
Now we see why algebra skills are important for Calculus.
What is a basic derivative problem?
A basic derivative problem is a type of mathematical problem that involves finding the rate of change of a function at a specific point. It is a fundamental concept in calculus and is used to solve a variety of real-world problems.
How do you solve a basic derivative problem?
To solve a basic derivative problem, you first need to differentiate the given function using the rules of differentiation. Then, substitute the value of the given point into the derivative to find the rate of change at that point.
Why is understanding basic derivative problems important?
Understanding basic derivative problems is important because it is a crucial concept in calculus and is used in various fields such as physics, engineering, and economics. It allows us to analyze and make predictions about the behavior of functions.
What are some applications of basic derivative problems?
Some applications of basic derivative problems include finding the velocity and acceleration of moving objects, determining maximum and minimum values of functions, and solving optimization problems.
What are some common mistakes when solving basic derivative problems?
Some common mistakes when solving basic derivative problems include not applying the correct differentiation rules, making arithmetic errors, and not understanding the meaning of the derivative in the context of the problem.
