• Support PF! Buy your school textbooks, materials and every day products Here!
Another eigenvalue problem.
  • Thread starter snoggerT
Find a 2\times 2 matrix A for which
E_4 = span [1,-1] and E_2 = span [-5, 6]
where E_(lambda) is the eigenspace associated with the eigenvalue (lambda)
relevant equations: Av=(lambda)v
3. The Attempt at a Solution
I've pretty much gotten most of the eigenspace/value problems down, but this one I'm clueless on how to work. Seems that you would have to work backwards , but I don't know how to do that.
Answers and Replies
CompuChip
4,284
47
Suppose you have a matrix A and it is diagonalizable. That means you can write it as
[tex]A = C D C^{-1}[/tex]
When A is given, how can you construct the matrices C and D?
Once you answer this question, you'll also see the answer to your problem.
HallsofIvy
41,738
897
You can just do it directly. You are told that
[tex]\left(\begin{array}{cc}a & b \\ c & d\end{array}\right)\left(\begin{array}{c}1 \\ -1\end{array}\right)= 4\left(\begin{array}{c}1\\ -1\end{array}\right)= \left(\begin{array}{c}4\\ -4\end{array}\right)[/tex]
which gives you two equations for a, b, c, d and
[tex]\left(\begin{array}{cc}a & b \\ c & d\end{array}\right)\left(\begin{array}{c}-5 \\ 6\end{array}\right)= 2\left(\begin{array}{c}-5\\ 6\end{array}\right)= \left(\begin{array}{c}-10\\ 12\end{array}\right)[/tex]
which gives you another two equations. Solve those 4 equations.
Related Threads for: Another eigenvalue problem.
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
