Another gravity problem Please help
  • Thread starter bcjochim07
bcjochim07
374
While visiting Planet Physics, you toss a rock straight up into the air at 11m/s and catch it 2.5 s later. While you visit the surface, your cruise ship orbits at an altitude equal to the radius of the planet every 230 min. What are the mass & radius of Planet Physics?
0m=0m + (11m/s)(2.5s) + .5a(2.5s)^2
ac=-8.8
230 min = 13800s angular velocity = 2pi rad/ 13800 = 4.55E-4 rad/s
ac= angular velocity^2 * r
8.8= (4.55E-4)* r
r=4.25 * 10 ^7 m This is not the correct answer. Could someone please explain what I am doing wrong?
Answers and Replies
Hootenanny
Staff Emeritus
Note that your altitude is equal to the radius of the planet, which means that your cruise ship is 2r from the centre of the planet.
bcjochim07
374
ohhhh... of course. Thanks
Hootenanny
Staff Emeritus
bcjochim07
374
wait a second, If I divide my answer by 2, I still don't get the right answer, which is 1.33E6 m
Hootenanny
Staff Emeritus
The acceleration that you calculated earlier is the acceleration on the surface, i.e. at r, whereas your cruise ship is orbiting at 2r.
bcjochim07
374
Would the gravity be one fourth of what it is at the surface? Nope... that doesn't work either.
bcjochim07
374
I really am not sure what to do
Kurdt
Staff Emeritus
You're equating two things that are incompatible. The acceleration at the height of the ship is not the same as at the surface of the planet. If you consider setting up two equations in terms of the mass of the planet and the radius, then you can eliminate a variable.
bcjochim07
374
Ok, here's what I tried:
since at the surface of the planet
g= GM/R^2
R= sqrt[ GM/g]
I calculated g at the surface to be 8.8 m/s^s
so I substituted that into the equation:
R= sqrt[GM/8.8]
Then I move on to the orbit which is 2R from the center
So the g of the ship would be
gship= GM/(2*sqrt[GM/8.8])^2
I get gship= 2.2 m/s^2
But using the equation a= angular velocity^2 * r
I again get a wrong value for r.
Kurdt
Staff Emeritus
g= GM/R^2
R= sqrt[ GM/g]
R= sqrt[GM/8.8]
This part is good.
The ship is still at [itex]2r[/itex].
bcjochim07
374
That's why I multiplied my expression for R by 2
Kurdt
Staff Emeritus
It was that bit to which I was referring in my previous post. Sorry for not making that clear.
bcjochim07
374
2.2 m/s^2 = (4.55E-4)^2*r
r= 1.06E7
this r is the distance between the ship and the center of the planet
So then I divide by 2 to get the radius of the planet: 5.31E6 m
But that's not the correct answer
Kurdt
Staff Emeritus
Is this entered online? I get that as the answer for the radius.
bcjochim07
374
no, it's the answer in the back of my textbook
Kurdt
Staff Emeritus
Are you sure the question is as it is stated the book? Failing that I'll get someone else to check that I haven't missed something by mistake. What is the answer in the book out of curiosity?
bcjochim07
374
no, It's from the back of my textbook
Shooting Star
1,982
I get the radius as ~ 5.31E6 m.
EDIT: Sorry, bcjochim07. I didn't see that you've already given the answer in post #5.
alphysicist
2,238
Hi Shooting Star,
In post #5 he said the book's answer was 1.33e6 m. I got the same answer that you and he did.
Suggested for: Another gravity problem Please help
  • Last Post
  • Last Post
  • Last Post
