What is the maximum speed achieved by a spaceship traveling to Moon Base I?
In summary, the spaceship travels a straight line path from Earth to Moon Base I with an acceleration of 19.4 m/s2 for the first 14.4 minutes and then travels at a constant speed until the last 14.4 minutes when it decelerates to rest at the moon. The maximum speed attained can be found using the formula for the area of a trapezoid. The fraction of the total distance traveled at constant speed can be calculated using a v-t graph. The total time required for the trip can be found by converting the time in minutes to seconds. Graphing can be a helpful tool in solving this type of problem.
azila
67
Another hard physics problem??
A spaceship ferrying workers to Moon Base I takes a straight line path from the Earth to the moon, a distance of 384000 km. Suppose it accelerates at an acceleration 19.4 m/s2 for the first time interval 14.4 min of the trip, then travels at constant speed until the last time interval 14.4 min when it accelerates at 19.4 m/s2 just coming to rest as it reaches the moon.
A. What is the maximum speed attained
B. What fraction of the total distance is traveled at constant speed
C. What total time is required for the trip
So, I made a table
X Vo V A t
First Time interval 2011.39 0 279.36 19.4 14.4
Constant Speed 379977 279.36 ? ? ?
Last time interval 2011.39 ? ? 19.4 14.4
First of all, is acceleration 0 when velocity is constant? If it is then in the constant speed time, the acceleration is zero and then the velocity would be the same. But I don't know how to get the max speed attained. What should I do? I tried using every one of the constant acceleration equations. When I tried solving for time, it was giving me 22 hours and that is not the answer. So please, if you can help me a bit out. Thanks
So, I made a table
X Vo V A t
yes, the acceleration is zero when the velocity is constant.
You seemed to have made a mistake with the units. You must put the time in seconds if you use an acceleration in m/s^2
it's good to make a graph for these types of questions..
then you really don't need to know any of those formulas ^^
for this, a v-t graph can help a lot
"I don't know how to get the max speed attained. What should I do? I tried using every one of the constant acceleration equations. When I tried solving for time, it was giving me 22 hours and that is not the answer. So please, if you can help me a bit out. Thanks"
ignore everything else, but this statement: " Suppose it accelerates at an acceleration 19.4 m/s2 for the first time interval 14.4 min of the trip, "
answer to your first question
Hint(if you trying graph way): Area of trapezoid = 0.5*v*(t when v is contant)*(t when v is contant+2*14.4)=total distance
Ok, thanks for telling me to convert the time in seconds because the time needs to be in seconds for the equation to work. Thanks rootx for the formula, I used that to get it. Yeah, graphing really helps. Thanks again for every ounce of help.
What is the difficulty level of this hard physics problem?
The difficulty level of a physics problem can vary depending on the individual's level of understanding and familiarity with the subject matter. However, a problem may be considered "hard" if it requires a high level of mathematical and analytical skills, as well as a deep understanding of the underlying principles and concepts.
How can I approach solving this hard physics problem?
There is no one-size-fits-all approach to solving a hard physics problem. However, some general strategies include breaking the problem down into smaller, more manageable parts, using relevant equations and principles, and seeking guidance from textbooks or online resources.
What should I do if I get stuck on a hard physics problem?
If you find yourself stuck on a hard physics problem, take a break and come back to it with a fresh perspective. You can also try discussing the problem with a classmate or seeking help from a teacher or tutor. Sometimes, simply talking through the problem with someone else can help clarify your thinking.
What are some common mistakes to avoid when solving a hard physics problem?
Common mistakes when solving hard physics problems include not fully understanding the problem, using incorrect formulas or equations, and making errors in calculations. It's important to carefully read and analyze the problem before attempting to solve it, and double-check your work for any mistakes.
How can I improve my problem-solving skills for hard physics problems?
Improving problem-solving skills for hard physics problems takes time and practice. Some tips include regularly practicing with different types of problems, seeking out challenging problems, and seeking feedback from teachers or tutors. It's also important to review and understand any mistakes made during problem-solving to avoid repeating them in the future.
