Homework Help: Another homework question
  1. Dec 12, 2006 #1
    Another question on my homwork reads: "For what value of k does
    [tex]\left\{\begin{array}Kx+2y=12\\9x+2y=8\end{array}\right[/tex] have no solution? Justify."
    Is the answer 9 or -9, or neither? I don't understand it, nor can I justify it.
  3. Dec 12, 2006 #2
    Sorry, there should be a k in front of the x in the 1st equation.
  4. Dec 12, 2006 #3
    cristo
    Staff Emeritus
    Try subtracting the 2nd eqn from the 1st. Does this help?
  5. Dec 12, 2006 #4
    So then it would be 9? Because it would then be 0 = 4, and that would make it inconsistent?
  6. Dec 12, 2006 #5
    cristo
    Staff Emeritus
    Yes, or to put it another way (k-9)x=4 has no solution for k=9, since division by 0 is not defined.
  7. Dec 12, 2006 #6
    Ok that makes sense. But one more thing...how can you determine whether to subtract the 2nd equation from the 1st, or add them both together?
  8. Dec 12, 2006 #7
    cristo
    Staff Emeritus
    Because 2y appears in both equations. Subtracting makes them cancel out so you can get an expression for x.
    In fact, you dont have to subtract at all, you can just spot that putting k=9 will make the LHS of both equations the same, whereas the RHS of both are different. This shows inconsistency in the set of equations.
    However, I just suggested subtracting, since this would enable you to spot the answer more quickly!
  9. Dec 12, 2006 #8
    Ohhhh ok it all makes sense now. Thank you very much for all your help.
Loading...
