The Metric Matrix: How Can I Invert a Non-Diagonal Matrix?
  • A
  • Thread starter MathematicalPhysicist
  • Tags
    Metric
In summary: Its easy to invert$$\left(\begin{array}{cc|c|c}0 & \tfrac12 & 0 & 0 \\\tfrac12 & F & 0 & 0 \\\hline 0 & 0 & 1 & 0 \\\hline 0 & 0 & 0 & 1\end{array}\right)$$provided you remember how to invert$$\begin{pmatrix}0 & \tfrac12 \\\tfrac12 & F... & 0
371
I have the metric ##ds^2=dudv+F(y,z)du^2+dy^2+dz^2##.
I have shown that for ##F(y,z)=0## it's Minkowski metric, but for ##F(y,z)\ne 0 ## I want to calculate Christoffel Symbols, Ricci tensor and scalar, the problem is that the metric ##g_{\mu\nu}## is not diagonal, and I need to find ##g^{\mu\nu}## in order to calculate christoffel and the rest, but how can I solve this without inverting the metric?
Thanks!
Why do you need to do it without inverting the metric? The metric has a straight-forward inverse.
Well we have a matrix: {0,1,0,0},{1,F(y,z),0,0},{0,0,1,0},{0,0,0,1}
So it's not diagonal, so inverting it you need to use the algorithm from Linear Algebra.
Ah, yes, the inverse is easy, didn't notice it.
:-D
So? Is that a problem?
EDIT: Still, if it wasn't easy I see no problem in using linear algebra. That's why you learned it - to use it.
Also, I strongly suggest against using the typical expression in terms of the metric to compute the connection coefficients of the Levi-Civita connection. Instead, use the geodesic equations obtained from finding the optima of
\int g_{\mu\nu}\dot x^\mu \dot x^\nu ds.
It is the same maths, but the bookkeeping is way easier.
I know, but if there are less tedious methods just in case...
Likes weirdoguy
BTW, does someone know how to implement the calculation of Christoffel symbol, Ricci tensor and Ricci scalar in maple?
I just want to check if my calculations are right, I got:
The only Christoffel symbols that don't vanish are: ##\Gamma_{uu}^y=-F'_y(y,z)/2## and ##\Gamma_{uu}^z=-F'_z(y,z)/2##; and the Ricci tensor the components that don't vanish are:
$$R^y_{uyu}=-F''_{yy}/2$$
$$R^z_{uzu}=-F''_{zz}/2$$
$$R^y_{uzu}=R^z_{uyu}=-F''_{yz}/2$$
I get that Ricci scalar vanishes since ##R=R^{\alpha}_{\beta\mu\alpha}g^{\beta\mu}=0##, am I right?
I don't understand how to use this package in maple 2017, I asked for help in a suitable forum for maple, but didn't get yet an answer.
Did you get the point of #6? It really is the most straight-forward way of computing the Levi-Civita connection coefficients.
I get more non-zero Christoffel symbols. In particular, look for ##\Gamma^v_{uy} = \Gamma^v_{yu}## and ##\Gamma^v_{uz} = \Gamma^v_{zu}##. Can you show your work?
That's the Riemann tensor. The Ricci tensor is ##R_{\mu\nu} = R^{\gamma}_{\mu\gamma\nu}##. There are also some non-zero elements of the form ##R^v_{abc}##, where ##abc## are all different from ##v##, but they do not affect the computation of the Ricci scalar or the Ricci tensor since they never correspond to one of the lower indices and therefore disappear in the trace. Therefore:
Yes. I get a vanishing Ricci scalar as well.
Yes, I get that ##\Gamma_{uy}^v=1/4F_y'## and ##\Gamma^v_{uz}=1/4F_z'##, I think this about sums it for Christoffel symbol.
I can scan my work, I just inverted the metric with an LA algorithm (where you augment ##g_{\mu\nu}## with the identity matrix and then get on the left the identity matrix and on the right the inverse matrix).
Some years ago I used a Maple package called GRTensor II which I ran under the symbolic toolbox in Matlab.
Cheers
I got a different constant. Using the method described in #6 your work for the Christoffel symbols should not be longer than a few lines (one for the variation with respect to each coordinate). The relevant variations are the variations with respect to ##u## and ##v## of
\int \underbrace{[\dot u \dot v + F \dot u^2 + \dot y^2 + \dot z^2]}_{\equiv \mathscr L} ds.
\end{array}\right)
\begin{pmatrix}
0 & \tfrac12 \\
\tfrac12 & F
\end{pmatrix}
Likes MathematicalPhysicist
1. What is another metric question?
Another metric question is a question that seeks to measure or quantify a specific aspect or variable in a scientific study or experiment. It is often used to collect data and analyze results.
2. Why is it important to ask another metric question?
Asking another metric question allows scientists to gather more comprehensive and accurate data, which can lead to more reliable and meaningful conclusions. It also helps to ensure that all relevant aspects are considered in the research process.
3. How do you come up with another metric question?
Another metric questions can be developed by identifying the key variables or factors that are relevant to the research topic and then formulating questions that directly measure or assess these variables.
4. Can another metric question be used in any field of science?
Yes, another metric questions can be used in any field of science, as long as there is a need to collect and measure data. It is particularly useful in quantitative research methods, but can also be incorporated into qualitative studies.
5. Are there any tips for asking an effective another metric question?
To ask an effective another metric question, it is important to be specific, clear, and unbiased. Avoid using leading or loaded language, and make sure the question is relevant to the research topic. It can also be helpful to pilot test the question with a small sample before using it in a larger study.
