Another Momentum Question
  • Thread starter niki4d
A 5.00 X 10^-3 kg steel ball moving 1.20m/s collides elastically (no loss of kinetic energy) with an identical, stationary steel ball. The incident ball is deflected 30 degrees from its original path.
(a) Draw a vector diagram showing the paths of both balls after the perfectly elastic collision.
(b) What is the velocity of the incident ball after the collision?
All I used is the initial momentum = final momentum theorem and p=mv.
a
I drew the vector diagram: ----->
\30d |
p=mv \ |
=.006kgm/s \ |
a=.005196kgm/s
p=mv
v= 1.04m/s
Is this the correct way to do it? I think i mixed some things up as the velocity I found was for the horizonal vector, which should be the struck ball.. It feels like I made a real obvious mistake.. but its just out of reach.. :cry:
Answers and Replies
Oh, no.. the vector diagram didn't turn out in the post..
a
the hypotnuse is where i put the p=mv equation and solved. I ended up with the velocity of the horizontal vector, which is not correct.
I hope this diagram shows up!
Apparently not.. next time I'll try a picture..
olgranpappy
1,271
that "diagram" is impossible for me to read... sorry.
anyways, you did well to recongize that you should use conservation of momentum, and energy. conservation of momentum is applied for each independant direction (each vector component), so you need to use the angles that the two balls make with the incident direction in your calculations. do you know what the angle that the second ball's velocity makes with the original direction?
Here is the diagram I drew. The 30 degree angle is on the left side. On the hypotnuse side I got .006kgm/s. and solving it for the stationary ball, i got the velocity as 1.04 m/s. (Used p=mv) Shouldnt 1.04m/s be for the incident ball though?
olgranpappy
1,271
nope. not the right diagram. angle between ball's velocities is wrong.
Would that be the right diagram or am I doing this completely wrong.. :bugeye:
The last diagram would be the same thing wouldn't it.. is this the right way?
olgranpappy
1,271
it's wrong because the ball which was initially stationary does *not* move straight forward along the horizontal axis. It's velocity also makes an angle with the horizontal axis. It is well-known (and should be in your book somewhere) that after the collision the angle between the velocities must be 90 degrees. You are given the angle which one ball's velocity makes with the horizontal, thus what must the other angle be?
Related Threads on Another Momentum Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
