Another question
  • Thread starter sid_galt
sid_galt
502
There are two concentric pipes. The outer pipe is ejecting air at 10 atm and 1200K. The inner pipe is ejecting air at 1 atm and 600K.Mass flow rate is the same and the air is being ejected into a common duct. What will happen?
Will the the two flows mix together in the common duct producing a medium pressure and medium temperature or will the outer pipe exert backpressure on the inner one preventing the air from getting out?
Answers and Replies
faust9
691
What do you think happens?
sid_galt
502
I think the backpressure from the outer flow and the mixed flow will be too much to overcome.
faust9
691
Yes, but the 'mixed' flow will occur within the smaller pipe not in the common duct.
Clausius2
To my understanding the answer is not an easy one. It would depend on the inertia of both streams. Maybe to answer your question it would be needed a numerical simulation. If the velocity of the low pressurized stream is small enough, then it could be a backwards flow from the high pressurized stream because the first one wouldn't have the needed inertia to convect the flow downstream.
faust9
691
The mass flow rates of the outer and inner fluid are the same though so inertial differences are negligible.
sid_galt
502
Or perhaps supersonic flow again with a converging diverging nozzle shape of the inner pipe. Although I don't have much idea how that will play out as the speed of sound is different in both the flows. My best guess is that oblique shock will not occur as the velocity of sound in the outer flow is much higher than in inner flow (assuming the mach numbers in the inner flow are very low but above 1) but as the flow inside the inner pipe is still supersonic, the pressure waves won't travel upwards and the flow wouldn't be blocked.
Clausius2
I don't care the inertia difference. I am talking about absolute inertia of each stream. Numerical simulation is needed here.
Suggested for: Another question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
