Homework Help: Another series/sequence proof
  1. Jun 17, 2009 #1
    Prove that if the infinite series a_1 + a_2 + ... + a_n, with positive decreasing terms, converges to a value A, then the limit as n approaches infinity of n*a_n = 0
    2. Relevant equations
    3. The attempt at a solution
    Assume [tex] \forall n \in Z^{+} ,\exists \epsilon > 0: n(a_n) \ge \epsilon [/tex], where Z+ is the set of all positive integers and of course, epsilon is fixed. Now, if n(a_n) >= epsilon, then a_n >= epsilon/n
    If epsilon >= 1, then a_n >= epsilon/n >= 1/n, for all n. But this can't be true because then
    a_1 >= 1/1, a_2 >= 1/2, a_3 >= 1/3 and so on, implying that a_1 + a_2 + ... + a_n >= 1/1 + 1/2 + 1/3 + 1/4 + ... = harmonic series, which diverges, and so a_n diverges, but a_n really converges.
    Now we consider 0 < epsilon < 1:
    There exists a fixed positive number c such that c*epsilon = 1. If n(a_n) >= epsilon, then
    cn(a_n) >= c*epsilon = 1, implying that c(a_n) >= 1/n for all positive integers n.
    And so, c(a_1) >= 1/1, c(a_2) >= 1/2, c(a_3) >= 1/3 and so on, implying:
    c(a_1) + c(a_2) + c(a_3) = c(a_1 + a_2 + ..) >= 1/1 + 1/2 + 1/3 + ... = harmonic series, which diverges, and so the infinite series c(a_1) + c(a_2) + .. must also diverge. However, c(a_1 + a_2 + ...) converges to the value cA, since c is a fixed value.
    These two contradictions both lead to the conclusion that there doesn't exist an epsilon such that n(a_n) >= epsilon for all positive integers n, meaning that n(a_n) < epsilon for all positive epsilon and for n large enough, meaning that the limit is 0.
    QED
    This proof looks fine to me, but the solution seems too simple. What is wrong with the proof?
  3. Jun 17, 2009 #2
    it seems that should work. maybe clarify a bit why you can have n*a_n > epsilon. also if you feel like you can put all this into a single step by noticing epsilon is fixed, while sum(1/n) goes unbounded independently of epsilon. you might need to prove that sum(1/n) is unbounded.
    if sum(a_n) converges it has a bound M say so that
    M>sum(a_n)>epsilon*(sum(1/N) > M for suff large N. contradiction. so you can choose epsilon > M/sum(1/N) for N sufficiently large...[edit: for any N!]
  4. Jun 17, 2009 #3
    Dick
    It is too simple. You didn't use that the sequence is monotone decreasing, which is an essential assumption. There error starts with "If n(a_n) >= epsilon". You seem to be assuming that is true for all integers. You can't assume that. The correct statement would be that there is an epsilon such that for any N>0, there is an n>N such that n(a_n)>epsilon. That is what n(a_n) does not converge to zero means. The correct proof does look a lot like the proof that the harmonic series diverges. Want to try it again? Here's a counterexample to think about. Define a_i=0 except where i=2^j for some integer j, then a_i=1/i. See? No monotone decreasing, no theorem.
  5. Jun 17, 2009 #4
    Ok, I just looked up the proof of the harmonic series and tried to model this proof after that, trying to get an infinite number of 1/2's...
    Assume that there exists an epsilon such that for any N > 0, there exists a positive integer n > N such that n(a_n) > epsilon. Let n1,n2,n3, ... be integers such that n1*2 < n2, 2*n2 < n3, 2*n3 < n4 and so on and for each ni, ni(a_ni) > epsilon.
    Then the infinite sum a1 + a2 + a3 + ... + an1 + a(n1 + 1) + ... + an2 + ... can be grouped as follows:
    (a1 + a2 + ... + an1) + (a(n+1) + ... + an2) + (a(n2+1) + ... + an3) + ...
    For the first group, a1 > a2 > ... > an1 > epsilon/n1 and so a1 + a2 + ... + an1 > n1(an1) = epsilon.
    For the second group, a(n1 +1) + a(n1 + 2) + ... + a(n2) > (n2 - n1)a(n2).
    Since n2 > 2n1, then n2 - 2n1 > 0 <-> 2n2 - 2n1 > n2 <-> 2(n2 - n1)> n2 <-> n2-n1>n2/2
    And so a(n1+1) + ... + a(n2) > (n2-n1)a(n2) > (n2/2)(epsilon/n2) = epsilon/2.
    For the third group, a(n2 + 1) + ... + a(n3) > (n3 - n2)a(n3) > (n3/2)(epsilon/n3) = epsilon/2
    And so (a1 + a2 + ... + an1) + (a(n1 +1) + ... + an2) + ... > epsilon + epsilon/2 + epsilon/2 + ... = epsilon(1 + 1/2 + 1/2 + 1/2).
    The series 1 + 1/2 + 1/2 + ... diverges (this is used to prove the harmonic series diverges), and since epsilon is fixed, epsilon(1 + 1/2 + 1/2 + ...) also diverges, showing that a1 + a2 + a3 + ... diverges, even though it really converges. This is a contradiction and so n*an has a limit of 0.
  6. Jun 17, 2009 #5
    Dick
    That's it. Congratulations. I haven't read every line of the proof, because I'm lazy, but I see all of the right ideas. If you believe it, I do.
