• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Another Simple Physics Problem
  • Thread starter freeofwork
Two steel wires are stretched with the same tension. The first wire has a diameter of .00059 meters and the second wire has a diameter of .00089m. If the speed of waves traveling along the first wire is 54.0 m/s, what is the speed of the waves along the second wire?
2. Relevant equations
v=√Ft/μ
μ=m/L
3. The attempt at a solution
I have no idea how to get the mass or length of the string...
1,195
Hint: You know the diameters so you know the mass per unit length of each.
what would be the equation for that... i only know μ=m/L...
1,195
You know the formula for velocity. The tension is the same for both wires. Mu is mass per unit length which you can determine by realizing that a wire is a cylinder. You know the velocity of the wave on one of the wires. Therefore, you can solve this without knowing the respective wire lengths.
imdont have e height though... how can you convert the diameter into something usable...
1,195
m/l is mass per unit length.
1,195
What's the formula for the volume of a cylinder?
1,195
That's correct or you could also say (pi d^2/4)h. So what would be the mass per unit length?
radical x over 54^2?
x being the tension?..
1,195
Do you know what mass per unit length means?
linear density
1,195
In the case of a wire which is a cylinder the mass per unit length is:
m/L = rho * Volume/L = rho * pi * d^2/4 * L/L = rho * pi * d^2/4
where rho is the density in kg/meter^3.
You have the formula for the velocity of one wave at a specific m/L. You want the velocity of the wave in the other wire. The tensions are the same.
V1^2 = F/mu1 and V2^2 = F/mu2. Think about (V1/V2)^2.
1,195
Got to hurry here. Giants-Falcons game starts in 11 minutes!
how do you find the density or linear density? this is crazy
1,195
You do not the actual number; you only need the ratio of the two.
idk....
i dont know.
1,195
Ok, I shall provide more help. I cannot do it for you -forum rules.
Form a ratio for v1/v2. You know one of the v's. This ratio equals square root of mass per unit length ratios. You can compute this ratio. This leaves one unknown.
what do u mean by mass per unit ratios?
1,195
(M1/Ll)/(M2/L)
M's are dependent on diameters. L's drop out.
o how would u get e mass?
so the equation who look something like this?
v1/v2=√m1m2
1,195
You almost have it. Check your algebra. The radical should be m2/m1. Relate the m's to their respective diameters....
i dont know how the mass are related to the diameters...
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
