Discover the Heat Transfer in a Thermo-Aluminum Calorimeter with Metallic Blocks
  • Thread starter PrudensOptimus
  • Tags
    Thermo
In summary, an experiment was conducted with an aluminum calorimeter containing 250 g of water at 12.0°C. Two metallic blocks, a 40.0 g piece of copper at 80.0°C and a 13.0 g block at 116.0°C, were added to the water. The final temperature of the system stabilized at 15.0°C. The total heat lost by the two blocks is 4049 J. The mass and final temperature of the unknown block are still unknown.
PrudensOptimus
641
An aluminum calorimeter of mass 100 g contains 250 g of water. The calorimeter and water are in thermal equilibrium at 12.0°C. Two metallic blocks are placed into the water. One is a 40.0 g piece of copper at 80.0°C; the other block has a mass of 13.0 g and is originally at a temperature of 116.0°C. The entire system stabilizes at a final temperature of 15.0°C.
Here's what I have so far:
(mcΔT)A + (mcΔT)W = (mcΔT)Cu + (mcΔT)Unknown
100(3) + 250(3) = 40(67) + 13(103)
300 + 750 = 2710 + 1339
1050 = 4049
It looks like the total heat lost by the two blocks is 4049 J. Is that correct? What is the mass and final temperature of the unknown block?
Where:
m = mass
c = specific heat capacity
ΔT = change in temperature
A = aluminum calorimeter
W = water
Cu = copper block
Unknown = unknown metallic block
To solve for the specific heat capacity of the unknown metallic block, we can rearrange the equation to:
cUnknown = [(mcΔT)A + (mcΔT)W - (mcΔT)Cu] / (mΔT)Unknown
Plugging in the given values, we get:
cUnknown = [(100g)(0°C - 15°C) + (250g)(0°C - 15°C) - (40.0g)(80.0°C - 15.0°C)] / (13.0g)(116.0°C - 15.0°C)
cUnknown = -15000 J / (13.0g)(101.0°C)
cUnknown = -11.65 J/g°C
This negative value suggests that the unknown metallic block has a lower specific heat capacity than the other materials in the system, meaning it can absorb heat more easily. This could indicate that the unknown block is made of a metal with a lower atomic mass, such as silver or gold. Further experiments and calculations would be needed to confirm this hypothesis.
1. What is a Thermo-Aluminum Calorimeter?
A Thermo-Aluminum Calorimeter is a scientific instrument used to measure the heat transfer between two substances. It consists of a hollow aluminum container filled with a known amount of water, and metallic blocks that can be heated or cooled and placed inside the container.
2. How does heat transfer occur in a Thermo-Aluminum Calorimeter?
Heat transfer occurs through conduction in a Thermo-Aluminum Calorimeter. When the metallic blocks are heated or cooled, they come in direct contact with the water inside the aluminum container, causing the transfer of thermal energy from the blocks to the water.
3. What is the purpose of using metallic blocks in a Thermo-Aluminum Calorimeter?
The metallic blocks serve as the heat source or sink in the Thermo-Aluminum Calorimeter. They allow for controlled and measurable changes in temperature within the system, making it possible to calculate the heat transfer between the blocks and the water.
4. How is the heat transfer calculated in a Thermo-Aluminum Calorimeter?
The heat transfer is calculated using the equation Q = mcΔT, where Q is the heat transfer, m is the mass of water, c is the specific heat capacity of water, and ΔT is the change in temperature of the water before and after the blocks are placed in the calorimeter.
5. What are the applications of using a Thermo-Aluminum Calorimeter?
A Thermo-Aluminum Calorimeter is commonly used in scientific research and experiments to study the heat transfer properties of different substances. It can also be used to measure the specific heat capacity of materials and to study the effects of temperature changes on chemical reactions.
13K
