Why is there Proportionality instead of Equality in Young's Experiment?
  • Thread starter Syrus
  • Tags
    Wave
In summary, the conversation discusses the use of proportionality instead of equality in deriving line 2.14 in the experiment of Young's double slit. The person asking the question is unsure why this is the case and the other person explains that the specific intensities do not matter and only small deviations are assumed. The conversation also mentions adding the wave intensities to determine the overall intensity on the screen.
Syrus
214
The picture below shows line 2.14, which is derived based on some of the discussion from the text above (I assume it's fairly obvious the experiment is Young's). My question is, why is there a proportionality instead of an equality? No amplitudes are mentioned for the constituent waves eminating from each of the slits, so I figure this should be an equality?
Also, some lines below, the sentence "Note that we are adding the wave amplitudes here." appears. I don't, however, see any amplitude additions. Is this a mistake for "..adding the wave expressions here"?
It looks right. They are adding the wave intensities from each slit to determine the intensity on the screen and they show it from a top down perspective.
the sqrt expressions are the pythagorean distance from a given slit to a point on the screen (notice they take the center between the slits as x=0 and so each slit is +-s/2 from the center.
Yes, I unserstand that much, the only thing I am unsure of is why a proportionality is used as opposed to an equality. Any ideas?
They don't know and don't care what the actual intensities are. because they're assuming only small deviations from the midpoint, the two intensities will be almost the same.
I can explain the use of proportionality in Young's Experiment by considering the fundamental principles of wave interference. In this experiment, light waves from two slits interfere with each other to produce a pattern of light and dark fringes on a screen placed behind the slits. These fringes are a result of the superposition of the two waves from the slits, and the intensity of the light at each point on the screen is proportional to the square of the amplitude of the resulting wave.
This proportionality can be seen in the equation for the intensity of the light at a point on the screen, which is given by I ∝ A^2, where A is the amplitude of the resulting wave. This means that the intensity of the light at a point is directly proportional to the square of the amplitude of the resulting wave.
In Young's Experiment, the amplitudes of the waves from each slit are not equal, as the waves travel different distances to reach the screen. This difference in path length results in a phase difference between the two waves, which affects the amplitude of the resulting wave at each point on the screen. Therefore, the intensity of the light at each point is not equal, but rather proportional to the square of the amplitude of the resulting wave.
The sentence "Note that we are adding the wave amplitudes here." refers to the mathematical process of superposition, where the amplitudes of the waves are added together to determine the resulting wave. This is not a physical addition of amplitudes, but rather a mathematical representation of the interference of waves.
In conclusion, the use of proportionality in Young's Experiment is a result of the principles of wave interference, where the intensity of the light at each point on the screen is directly proportional to the square of the amplitude of the resulting wave. This is due to the unequal amplitudes of the waves from each slit and the process of superposition.
1. Why is there proportionality in Young's experiment?
The presence of proportionality in Young's experiment is due to the nature of light as a wave. When light passes through the two slits, it diffracts and creates an interference pattern. This pattern is created by the superposition of the waves from each slit, resulting in areas of constructive and destructive interference. The intensity of light at each point in the pattern is directly proportional to the amplitude of the waves, hence the presence of proportionality in the experiment.
2. How is proportionality different from equality in Young's experiment?
Proportionality in Young's experiment refers to the relationship between the intensity of light and the amplitude of the waves, while equality refers to the equal distribution of light intensity across the interference pattern. In other words, proportionality explains the variation in intensity, while equality explains the uniformity of light distribution.
3. What factors affect the proportionality in Young's experiment?
The proportionality in Young's experiment can be affected by various factors, such as the distance between the slits, the wavelength of light, and the distance between the slits and the screen. These factors can alter the interference pattern and, therefore, affect the proportionality of light intensity in the experiment.
4. Why is proportionality important in Young's experiment?
Proportionality is important in Young's experiment as it helps to explain the phenomenon of interference and the behavior of light as a wave. It also allows scientists to accurately measure the wavelength of light and study the properties of light. Additionally, proportionality helps to validate the wave nature of light, which was a significant discovery in the field of optics.
5. Can proportionality be observed in other experiments besides Young's experiment?
Yes, proportionality can be observed in other experiments involving waves, such as diffraction, interference, and resonance. For example, in diffraction patterns, the intensity of light is also directly proportional to the amplitude of the waves. In interference experiments like the double-slit experiment, proportionality is also observed in the intensity of light at different points in the interference pattern.
  • Quantum Physics
  • Quantum Interpretations and Foundations
