Homework Help: Another work problem help!
  1. Oct 6, 2012 #1
    Sorry for the second post, but I want to know how to solve such problem when it comes to this situation.
    A vertical rope is used to lower a block of mass M = 48.3 kg at a constant acceleration of magnitude a = 1.54 m/s2. Find WT, the work done by the tension in the cord if the mass moves down distance s = 2.47 m.
    2. Relevant equations
    →W = mad
    3. The attempt at a solution
    Hm... Tried to use this form:
    W = m(g - a)d
    But I'm not sure if I'm at the right path.
  3. Oct 6, 2012 #2
    It seems correct to me :)
    m(g-a) is the force used to reduce the block acceleration.
    then m(g-a)d is the work done..nothing else to be considered anymore from here
  4. Oct 6, 2012 #3
    tiny-tim
    Hi NasuSama! :smile:
    No.
    The definition of work done is W = F "dot" d
    How did you get that equation? Did you use F = ma?
    If so, your F is correct, your d is correct, but your "dot" isn't. :wink:
  5. Oct 6, 2012 #4
    So W = F * d [Can't do the dot].
    I used F = ma to get the equation. What about the answer? Is it correct. You said F is correct and d is correct, right?
    My answer is around 987 J, but it's incorrect.
  6. Oct 6, 2012 #5
    W = m(g - a) [dot] d doesn't seem quite right.
  7. Oct 6, 2012 #6
    Never mind. I got the solution!
Loading...
