ANSYS & Dentistry
  • Thread starter vladanea
Main Question or Discussion Point
Can anybody help me please to find some tutorials about how can be used ANSYS in dentistry or something related with? Please help me if you can! Thank you!!!
Answers and Replies
minger
IIRC dentists are the tooth-doctors right?
Um....critical speed of the drill?
Do you guys get a lot of stress/strain related problems in dentistry?
FredGarvin
Maybe problems of beams on elastic foundations?
Mech_Engineer
171
Thyere are no "tutorials" covering the topic you are looking for (it seems poorly defined anyway). Generally ANSYS can't really be used in dentistry; but it can be used in the engineering design of dentistry tools.
You're going to have to refine your question significantly before we can help you.
Dear Mech_Engineer, you mean that with ANSYS I can't create something to look like a tooth and with ANSYS to apply one or more forces on it?
And if I have to
, I would say that I am not experienced with this software and I'd like to learn more about how can I create different shapes (2D and 3D) (which to look like a tooth!), how can I make such a shape to look realistic and so on. I hope you understand me this time and I hope you can advise me now:)
Thank you all of you!
Mech_Engineer
171
"Dentistry is the known evaluation, diagnosis, prevention, and treatment of diseases, disorders and conditions of the oral cavity, maxillofacial area and the adjacent and associated structures and their impact on the human body."
With this definition of dentistry in mind, ANSYS is pretty much useless in the general practice of dentistry; however, it is commonly used in the fields of biomechanics and biomedical engineering (which I get the feeling is more what you're after). To answer your question, ANSYS is of course able to take a solid model of a tooth for example and apply forces to it and calculate stresses (assuming you have accurate models of the tooth's constituent components). Making a structural model of a tooth is possibly less straightforward than you might think, but it is possible.
Creating a solid model of a tooth in ANSYS would be a difficult thing to do I suspect, mainly because it's solid modeling capabilities are somwhat limited. however if you were able to make a model of a tooth in another program more well-suited to the task (or possibly import a 3-d scan of an actual tooth, ANSYS could certainly import the model and do a structural analysis of it.
And if I have to , I would say that I am not experienced with this software and I'd like to learn more about how can I create different shapes (2D and 3D) (which to look like a tooth!), how can I make such a shape to look realistic and so on. I hope you understand me this time and I hope you can advise me now:)
Well, ANSYS makes a somewhat simplistic CAD software solution called DesignModeler which can be used to make simple CAD models; but its features are somewhat limited and it doesn't have the advance surface spline manipulation tools that a package like SolidWorks has. So, I would say that your best bet is either to find a 3-D scan of a tooth you can import into ANSYS, of find a CAD package that has more powerful geometry tools that can be used to manually model a tooth.
Another problem with modeling the tooth, would be how your constrain it and apply material properties to it... You couldn't really use a fixed condition at the root because the tooth is rooted in soft tissue and bone. Additionally, you would have to decide how you wanted to model the biting force on the top of the tooth, either with a pressure over an area or a point load. The material properties of the tooth would be difficult because the tooth has a hollow fleshy center and a hard outer layer of enamel. How this was modeled, and what the material properties of those parts are would play a significant role in your model.
I have actually modeled teeth in ANSYS. However, the geometry was created using a laser scanner and I had to import the stl file into ICEM in order to mesh it. Then import the mesh into ANSYS Mechanical in order to load it. It was very difficult. If you are a newbie to ANSYS, then I suggest you get some help. I have been building ANSYS models for about 5 years and this was the hardest one I ever had to do.
Also, when using scanned stl geometry, there can be a lot of repair work needed on the geometry before a mesh can be generated and that was why I had to use ICEM.
Dear CFDFEAGURU, can you help me please with such a source file created in ansys for a tooth? I am trying to prepare myself for a Ph.D. in dentistry and I really have no time to learn how to create something like that right now! Maybe we can collaborate in publishing a scientific paper if you are interested? Or, maybe we can talk more through email or yahoo messenger or anything you want? My email address is vladanea@gmail.com.
And for Mech_Engineer I have to thank you for your last post! Maybe you can help me too with this problem of mine? :)
Vlad
Sorry for the slow response, but I wouldn't be able to help you with this. That analysis was very difficult and more people than just I worked on it. Also, I don't have access to the ICEM meshing software that I used to do this with.
Sorry
Matt
Related Threads on ANSYS & Dentistry
  • Last Post
  • Last Post
  • Last Post
72K
28K
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
  • Last Post
