Homework Help: [ansys] simulation of permanent magnet in 3D
  1. Jun 5, 2015 #1
    The problem is to model a permanent magnet with a torus core .I just wanted to know how to attach attribute of magnet to a volume in ansys 15.0. I solved the problem in 2D but in 3D the results are not satisfactory and I'm not able to point out the mistake by me. the construction could be assumed to be a regular torus core with a section of permanent magnet with Hc 100000 A/m. Just a basic BSUM static analysis would be fine. I think this would be sufficient if not kindly reply. thanking for your best efforts.
    2. Relevant equations
    take Hc=100000
    3. The attempt at a solution
    the solution was attempted for a cubical core in 3D with SOLID236 ELEMENT.
    The generated log file is as below
    /BATCH
    /COM,ANSYS RELEASE 15.0 UP20131014 12:37:35 06/04/2015
    /input,menust,tmp,''
    /GRA,POWER
    /GST,ON
    /PLO,INFO,3
    /GRO,CURL,ON
    /CPLANE,1
    /REPLOT,RESIZE
    WPSTYLE,,,,,,,,0
    /NOPR
    KEYW,PR_SET,1
    KEYW,PR_STRUC,0
    KEYW,PR_THERM,0
    KEYW,PR_FLUID,0
    KEYW,PR_ELMAG,1
    KEYW,MAGNOD,1
    KEYW,MAGEDG,0
    KEYW,MAGHFE,0
    KEYW,MAGELC,0
    KEYW,PR_MULTI,0
    /GO
    /COM,
    /COM,Preferences for GUI filtering have been set to display:
    /COM, Magnetic-Nodal
    /PREP7
    ET,1,PLANE13
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDATA,MURX,1,,1
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDATA,MGXX,1,,
    MPDATA,MGYY,1,,1e6
    MPDATA,MGZZ,1,,
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDATA,MURX,2,,1e6
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDATA,MURX,3,,1
    RECTNG,0,0.15,0,0.1,
    *SET,al,0.2*0.15
    *SET,cl,0.6*0.15
    *SET,ct,0.01
    *SET,lg,0.001
    *SET,ch,0.03
    *SET,mh,0.018
    *SET,d,0.005
    RECTNG,al,cl+al,0,ct,
    RECTNG,al,0.04+al,ct,ct+ch,
    FINISH ! Make sure we are at BEGIN level
    /CLEAR,NOSTART ! Clear model since no SAVE found
    /COM,ANSYS RELEASE 15.0 UP20131014 12:51:22 06/04/2015
    ! WE SUGGEST YOU REMOVE THIS LINE AND THE FOLLOWING STARTUP LINES
    /GRA,POWER
    /GST,ON
    /PLO,INFO,3
    /GRO,CURL,ON
    /CPLANE,1
    /REPLOT,RESIZE
    WPSTYLE,,,,,,,,0
    /NOPR
    KEYW,PR_SET,1
    KEYW,PR_STRUC,0
    KEYW,PR_THERM,0
    KEYW,PR_FLUID,0
    KEYW,PR_ELMAG,1
    KEYW,MAGNOD,1
    KEYW,MAGEDG,0
    KEYW,MAGHFE,0
    KEYW,MAGELC,0
    KEYW,PR_MULTI,0
    /GO
    /PREP7
    ET,1,PLANE13
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDATA,MURX,1,,1
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDATA,MGXX,1,,
    MPDATA,MGYY,1,,1e6
    MPDATA,MGZZ,1,,
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDATA,MURX,2,,1e6
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDATA,MURX,3,,1
    *SET,al,0.2*0.15
    *SET,cl,0.6*0.15
    *SET,ct,0.01
    *SET,lg,0.001
    *SET,ch,0.03
    *SET,mh,0.018
    *SET,d,0.005
    RECTNG,0.04+al,0.04+al+ct,ct,ct+ch,
    APLOT
    /VIEW,1,,,-1
    /ANG,1
    /REP,FAST
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,1,2,3
    /ANG,1
    /REP,FAST
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    SAVE
    FINISH
    ! /EXIT,NOSAV
    /BATCH
    /COM,ANSYS RELEASE 15.0 UP20131014 12:52:18 06/04/2015
    /GRA,POWER
    /GST,ON
    /PLO,INFO,3
    /GRO,CURL,ON
    /CPLANE,1
    /REPLOT,RESIZE
    WPSTYLE,,,,,,,,0
    RESUME
    /COM,ANSYS RELEASE 15.0 UP20131014 12:52:21 06/04/2015
    /PREP7
    RECTNG,al+0.04-d,al+0.04+d,ct+ch+lg,ct+ch+lg+mh,
    RECTNG,al+0.04,al+0.04+ct,ct+2*ch+lg*2+mh,ct+ch+2*lg+mh,
    RECTNG,al,al+cl,ct+2*ch+lg*2+mh,ct+2*ch+2*lg+mh+ct,
    FLST,2,7,5,ORDE,2
    FITEM,2,1
    FITEM,2,-7
    AOVLAP,P51X
    FLST,5,4,5,ORDE,4
    FITEM,5,3
    FITEM,5,5
    FITEM,5,8
    FITEM,5,-9
    CM,_Y,AREA
    ASEL, , , ,P51X
    CM,_Y1,AREA
    CMSEL,S,_Y
    CMSEL,S,_Y1
    AATT, 2, , 1, 0,
    CMSEL,S,_Y
    CMDELE,_Y
    CMDELE,_Y1
    CM,_Y,AREA
    ASEL, , , , 4
    CM,_Y1,AREA
    CMSEL,S,_Y
    CMSEL,S,_Y1
    AATT, 1, , 1, 0,
    CMSEL,S,_Y
    CMDELE,_Y
    CMDELE,_Y1
    CM,_Y,AREA
    ASEL, , , , 10
    CM,_Y1,AREA
    CMSEL,S,_Y
    CMSEL,S,_Y1
    AATT, 3, , 1, 0,
    CMSEL,S,_Y
    CMDELE,_Y
    CMDELE,_Y1
    SMRT,6
    SMRT,2
    MSHAPE,0,2D
    MSHKEY,0
    FLST,5,6,5,ORDE,4
    FITEM,5,3
    FITEM,5,-5
    FITEM,5,8
    FITEM,5,-10
    CM,_Y,AREA
    ASEL, , , ,P51X
    CM,_Y1,AREA
    CHKMSH,'AREA'
    CMSEL,S,_Y
    AMESH,_Y1
    CMDELE,_Y
    CMDELE,_Y1
    CMDELE,_Y2
    FLST,2,8,4,ORDE,6
    FITEM,2,2
    FITEM,2,4
    FITEM,2,-5
    FITEM,2,23
    FITEM,2,33
    FITEM,2,-36
    DL,P51X, ,AZ,0,
    APLOT
    CM,magnet,AREA
    /UI,MESH,OFF
    CM,coreupper,AREA
    CM,corelower,AREA
    CMSEL,S,CORELOWER
    CMSEL,U,CORELOWER
    /MREP,EPLOT
    CMDELE,MAGNET
    CMDELE,COREUPPER
    CMDELE,CORELOWER
    /MREP,EPLOT
    ESEL,S,MAT,,1
    APLOT
    EPLOT
    CM,magnet,ELEM
    ALLSEL,ALL
    APLOT
    ESLA,S
    EPLOT
    ESLA,R
    /REPLOT,RESIZE
    APLOT
    FLST,5,42,2,ORDE,4
    FITEM,5,1
    FITEM,5,-21
    FITEM,5,69
    FITEM,5,-89
    ESEL,S, , ,P51X
    EPLOT
    CM,core,ELEM
    ALLSEL,ALL
    APLOT
    FMAGBC,'CORE','MAGNET'
    CMDELE,CORE
    /MREP,EPLOT
    FLST,5,30,2,ORDE,12
    FITEM,5,1
    FITEM,5,-4
    FITEM,5,6
    FITEM,5,8
    FITEM,5,13
    FITEM,5,-21
    FITEM,5,69
    FITEM,5,-72
    FITEM,5,74
    FITEM,5,76
    FITEM,5,81
    FITEM,5,-89
    ESEL,S, , ,P51X
    EPLOT
    CM,core,ELEM
    ALLSEL,ALL
    APLOT
    FINISH
    /SOL
    MAGSOLV,0,3,0.001, ,25,
    FINISH
    /POST1
    SET,FIRST
    /VSCALE,1,1,0
    PLVECT,B, , , ,VECT,ELEM,ON,0
    /VSCALE,1,1,0
    PLVECT,FMAG, , , ,VECT,ELEM,ON,0
    /EFACET,1
    PLNSOL, FMAG,SUM, 0
    PLF2D,27,0,10,1
    PLESOL, FMAG,SUM, 0
    PRNSOL,FMAG,COMP
    FMAGSUM,'CORE'
    FMAGSUM,'MAGNET'
    /VSCALE,1,1,0
    PLVECT,H, , , ,VECT,ELEM,ON,0
    /EFACET,1
    PLNSOL, H,SUM, 0
    /VSCALE,1,1,0
    FINISH
    ! /EXIT,NOSAV
    /BATCH
    /COM,ANSYS RELEASE 15.0 UP20131014 14:34:44 06/04/2015
    /GRA,POWER
    /GST,ON
    /PLO,INFO,3
    /GRO,CURL,ON
    /CPLANE,1
    /REPLOT,RESIZE
    WPSTYLE,,,,,,,,0
    RESUME
    /COM,ANSYS RELEASE 15.0 UP20131014 14:34:52 06/04/2015
    APLOT
    /PREP7
    FLST,2,3,5,ORDE,2
    FITEM,2,1
    FITEM,2,-3
    AOVLAP,P51X
    RECTNG,al+cl-d,al+cl+d,ct+ch+lg,ct+ch+lg+mh,
    RESUME, PM_core,db,
    /COM,ANSYS RELEASE 15.0 UP20131014 14:37:55 06/04/2015
    APLOT
    FLST,2,3,5,ORDE,2
    FITEM,2,1
    FITEM,2,-3
    AOVLAP,P51X
    RECTNG,al+0.04,al+0.04+ct,ct+2*ch+2*lg+mh,ct+ch+lg+mh,
    RESUME, PM_core,db,
    /COM,ANSYS RELEASE 15.0 UP20131014 14:39:28 06/04/2015
    APLOT
    FLST,2,3,5,ORDE,2
    FITEM,2,1
    FITEM,2,-3
    AOVLAP,P51X
    RECTNG,al+0.04,al+0.04+ct,ct+2*ch+2*lg+mh,ct+ch+2*lg+mh,
    RECTNG,al,al+cl,ct+2*ch+2*lg+mh,ct+2*ch+2*lg+mh+ct,
    FLST,2,7,5,ORDE,2
    FITEM,2,1
    FITEM,2,-7
    AOVLAP,P51X
    CM,_Y,AREA
    ASEL, , , , 1
    CM,_Y1,AREA
    CMSEL,S,_Y
    CMSEL,S,_Y1
    AATT, 1, , 1, 0,
    CMSEL,S,_Y
    CMDELE,_Y
    CMDELE,_Y1
    FLST,5,4,5,ORDE,3
    FITEM,5,2
    FITEM,5,-4
    FITEM,5,8
    CM,_Y,AREA
    ASEL, , , ,P51X
    CM,_Y1,AREA
    CMSEL,S,_Y
    CMSEL,S,_Y1
    AATT, 2, , 1, 0,
    CMSEL,S,_Y
    CMDELE,_Y
    CMDELE,_Y1
    CM,_Y,AREA
    ASEL, , , , 9
    CM,_Y1,AREA
    CMSEL,S,_Y
    CMSEL,S,_Y1
    AATT, 3, , 1, 0,
    CMSEL,S,_Y
    CMDELE,_Y
    CMDELE,_Y1
    SMRT,6
    SMRT,2
    MSHAPE,0,2D
    MSHKEY,0
    FLST,5,6,5,ORDE,4
    FITEM,5,1
    FITEM,5,-4
    FITEM,5,8
    FITEM,5,-9
    CM,_Y,AREA
    ASEL, , , ,P51X
    CM,_Y1,AREA
    CHKMSH,'AREA'
    CMSEL,S,_Y
    AMESH,_Y1
    CMDELE,_Y
    CMDELE,_Y1
    CMDELE,_Y2
    ESEL,S,MAT,,1
    CM,magnet,ELEM
    ALLSEL,ALL
    ESEL,S,MAT,,2
    EPLOT
    ALLSEL,ALL
    APLOT
    FINISH
    /SOL
    FINISH
    /PREP7
    FLST,2,8,4,ORDE,8
    FITEM,2,2
    FITEM,2,4
    FITEM,2,-5
    FITEM,2,15
    FITEM,2,-16
    FITEM,2,25
    FITEM,2,33
    FITEM,2,-34
    DL,P51X, ,AZ,0,
    FMAGBC,'MAGNET'
    FINISH
    /SOL
    FINISH
    /POST1
    /VSCALE,1,1,0
    SAVE
    SAVE
    APLOT
    FINISH
    /SOL
    FINISH
    /POST1
    /EFACET,1
    PLNSOL, B,SUM, 0
    PLF2D,27,0,10,1
    /EFACET,1
    PLNSOL, FMAG,SUM, 0
    FINISH
    /PREP7
    K,100,0,0,0.05,
    klist,all,,,coord
    l,1,100
    LLIST,ALL, , ,
    aclear,all
    aplot
    vdrag,all,,,,,,3
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    /ANG,1,-30,YS,1
    /REP,FAST
    /ANG,1,-30,YS,1
    /REP,FAST
    /ANG,1,-30,YS,1
    /REP,FAST
    /ANG,1,-30,YS,1
    /REP,FAST
    /ANG,1,-30,YS,1
    /REP,FAST
    /ANG,1,-30,YS,1
    /REP,FAST
    /ANG,1,-30,YS,1
    /REP,FAST
    /ANG,1,-30,YS,1
    /REP,FAST
    /ANG,1,-30,YS,1
    /REP,FAST
    /ANG,1,-30,YS,1
    /REP,FAST
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    ET,2,SOLID236
    lplot
    SAVE
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    FLST,5,36,4,ORDE,27
    FITEM,5,2
    FITEM,5,23
    FITEM,5,25
    FITEM,5,29
    FITEM,5,33
    FITEM,5,-35
    FITEM,5,37
    FITEM,5,-38
    FITEM,5,41
    FITEM,5,43
    FITEM,5,45
    FITEM,5,-46
    FITEM,5,49
    FITEM,5,51
    FITEM,5,53
    FITEM,5,-54
    FITEM,5,56
    FITEM,5,58
    FITEM,5,60
    FITEM,5,63
    FITEM,5,-66
    FITEM,5,68
    FITEM,5,-69
    FITEM,5,71
    FITEM,5,-72
    FITEM,5,74
    FITEM,5,-81
    LSEL,S, , ,P51X
    LPLOT
    VPLOT
    vlist, all
    FLST,2,6,6,ORDE,2
    FITEM,2,1
    FITEM,2,-6
    VOVLAP,P51X
    FLST,5,4,6,ORDE,2
    FITEM,5,2
    FITEM,5,-5
    CM,_Y,VOLU
    VSEL, , , ,P51X
    CM,_Y1,VOLU
    CMSEL,S,_Y
    CMSEL,S,_Y1
    VATT, 2, , 2, 0
    CMSEL,S,_Y
    CMDELE,_Y
    CMDELE,_Y1
    CM,_Y,VOLU
    VSEL, , , , 1
    CM,_Y1,VOLU
    CMSEL,S,_Y
    CMSEL,S,_Y1
    VATT, 1, , 2, 0
    CMSEL,S,_Y
    CMDELE,_Y
    CMDELE,_Y1
    CM,_Y,VOLU
    VSEL, , , , 6
    CM,_Y1,VOLU
    CMSEL,S,_Y
    CMSEL,S,_Y1
    VATT, 3, , 2, 0
    CMSEL,S,_Y
    CMDELE,_Y
    CMDELE,_Y1
    MSHAPE,1,3D
    FLST,5,6,6,ORDE,2
    FITEM,5,1
    FITEM,5,-6
    CM,_Y,VOLU
    VSEL, , , ,P51X
    CM,_Y1,VOLU
    CHKMSH,'VOLU'
    CMSEL,S,_Y
    VMESH,_Y1
    CMDELE,_Y
    CMDELE,_Y1
    CMDELE,_Y2
    ESEL,S,MAT,,1
    VPLOT
    EPLOT
    CM,magnet,ELEM
    ALLSEL,ALL
    LPLOT
    VPLOT
    FLST,2,5,5,ORDE,3
    FITEM,2,28
    FITEM,2,36
    FITEM,2,-39
    DA,P51X,AZ,0,
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,-1
    /ANG,1
    /REP,FAST
    FLST,2,5,5,ORDE,5
    FITEM,2,12
    FITEM,2,22
    FITEM,2,-23
    FITEM,2,34
    FITEM,2,-35
    DA,P51X,AZ,0,
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    FINISH
    /SOL
    FMAGBC,'MAGNET'
    FINISH
    /POST1
    SAVE
    /EFACET,1
    PLNSOL, B,SUM, 0
    PLF2D,27,0,10,1
    /VSCALE,1,1,0
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,1,2,3
    /ANG,1
    /REP,FAST
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    /DIST,1,0.729,1
    /REP,FAST
    /DIST,1,0.729,1
    /REP,FAST
    /DIST,1,0.729,1
    /REP,FAST
    /DIST,1,0.729,1
    /REP,FAST
    /DIST,1,0.729,1
    /REP,FAST
    /DIST,1,0.729,1
    /REP,FAST
    /DIST,1,1.37174211248,1
    /REP,FAST
    /REP,FAST
    /REP,FAST
    /REP,FAST
    /REP,FAST
    /REP,FAST
    /VIEW,1,,1
    /ANG,1
    /REP,FAST
    /VSCALE,1,1,0
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,1,2,3
    /ANG,1
    /REP,FAST
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,,-1
    /ANG,1
    /REP,FAST
    /VIEW,1,-1
    /ANG,1
    /REP,FAST
    /VIEW,1,,-1
    /ANG,1
    /REP,FAST
    VSEL,S,MAT,,1
    VPLOT
    /VSCALE,1,1,0
    /VIEW,1,,-1
    /ANG,1
    /REP,FAST
    /VIEW,1,-1
    /ANG,1
    /REP,FAST
    /VIEW,1,,,-1
    /ANG,1
    /REP,FAST
    /VIEW,1,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    /VSCALE,1,1,0
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,1
    /ANG,1
    /REP,FAST
    FINISH
    /PREP7
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDE,MGXX,1
    MPDATA,MGXX,1,,0
    MPDE,MGYY,1
    MPDATA,MGYY,1,,1E+006
    MPDE,MGZZ,1
    MPDATA,MGZZ,1,,0
    FINISH
    /POST1
    /VSCALE,1,1,0
    FINISH
    /PREP7
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDE,MGXX,1
    MPDATA,MGXX,1,,1e6
    MPDE,MGYY,1
    MPDATA,MGYY,1,,0
    MPDE,MGZZ,1
    MPDATA,MGZZ,1,,0
    FINISH
    /SOL
    FINISH
    /POST1
    /VSCALE,1,1,0
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    FINISH
    /SOL
    APLOT
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,,-1
    /ANG,1
    /REP,FAST
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,,-1
    /ANG,1
    /REP,FAST
    FLST,2,13,5,ORDE,11
    FITEM,2,1
    FITEM,2,-4
    FITEM,2,8
    FITEM,2,11
    FITEM,2,16
    FITEM,2,21
    FITEM,2,27
    FITEM,2,32
    FITEM,2,-33
    FITEM,2,36
    FITEM,2,39
    DA,P51X,AZ,0,
    FINISH
    /POST1
    /VSCALE,1,1,0
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    FINISH
    /PREP7
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDE,MGXX,1
    MPDATA,MGXX,1,,0
    MPDE,MGYY,1
    MPDATA,MGYY,1,,0
    MPDE,MGZZ,1
    MPDATA,MGZZ,1,,1e6
    ! PLVECT,H, , , ,VECT,ELEM,ON,0
    /VIEW,1,1,1,1
    /ANG,1
    SAVE
    FINISH
    ! /EXIT,MODEL
    /BATCH
    /COM,ANSYS RELEASE 15.0 UP20131014 16:29:23 06/04/2015
    /GRA,POWER
    /GST,ON
    /PLO,INFO,3
    /GRO,CURL,ON
    /CPLANE,1
    /REPLOT,RESIZE
    WPSTYLE,,,,,,,,0
    RESUME
    /COM,ANSYS RELEASE 15.0 UP20131014 16:29:29 06/04/2015
    /PREP7
    MPTEMP,,,,,,,,
    MPTEMP,1,0
    MPDE,MGXX,1
    MPDATA,MGXX,1,,0
    MPDE,MGYY,1
    MPDATA,MGYY,1,,0
    MPDE,MGZZ,1
    MPDATA,MGZZ,1,,1E+006
    FINISH
    /SOL
    FINISH
    /POST1
    SET,FIRST
    /VSCALE,1,1,0
    /VIEW,1,,,1
    /ANG,1
    /REP,FAST
    PLF2D,27,0,10,1
    /EFACET,1
    PLNSOL, H,SUM, 0
    /VSCALE,1,1,0
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,1
    /ANG,1
    /REP,FAST
    /VSCALE,1,1,0
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    /VIEW,1,,,-1
    /ANG,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    NPLOT
    /VIEW,1,1,1,1
    /ANG,1
    /REP,FAST
    FLST,2,22,8
    FITEM,2,0.5E-01,0,0
    FITEM,2,0.5E-01,0.5E-01,0
    FITEM,2,0,0,0
    FITEM,2,0.5E-01,0,0
    FITEM,2,0.5E-01,0,0
    FITEM,2,0,0,0
    FITEM,2,0.5E-01,0,0
    FMAGSUM,'MAGNET'
    PRNSOL,H,COMP
    PRNSOL,FMAG,COMP
    FLST,5,2,1,ORDE,2
    FITEM,5,995
    FITEM,5,11480
    NSEL,S, , ,P51X
    NPLOT
    ALLSEL,ALL
    VPLOT
    LPLOT
    FINISH
    /PREP7
    FLST,2,6,6,ORDE,2
    FITEM,2,1
    FITEM,2,-6
    VCLEAR,P51X
    LPLOT
    FLST,5,33,4,ORDE,26
    FITEM,5,2
    FITEM,5,23
    FITEM,5,25
    FITEM,5,29
    FITEM,5,33
    FITEM,5,-35
    FITEM,5,37
    FITEM,5,-38
    FITEM,5,41
    FITEM,5,45
    FITEM,5,49
    FITEM,5,51
    FITEM,5,53
    FITEM,5,-54
    FITEM,5,56
    FITEM,5,58
    FITEM,5,60
    FITEM,5,62
    FITEM,5,-63
    FITEM,5,66
    FITEM,5,68
    FITEM,5,-69
    FITEM,5,71
    FITEM,5,-72
    FITEM,5,74
    FITEM,5,-81
    LSEL,S, , ,P51X
    LPLOT
    ALLSEL,ALL
    LPLOT
    FLST,5,35,4,ORDE,25
    FITEM,5,2
    FITEM,5,23
    FITEM,5,25
    FITEM,5,29
    FITEM,5,33
    FITEM,5,-35
    FITEM,5,37
    FITEM,5,-38
    FITEM,5,41
    FITEM,5,45
    FITEM,5,49
    FITEM,5,51
    FITEM,5,53
    FITEM,5,-54
    FITEM,5,56
    FITEM,5,58
    FITEM,5,60
    FITEM,5,62
    FITEM,5,-66
    FITEM,5,68
    FITEM,5,-69
    FITEM,5,71
    FITEM,5,-72
    FITEM,5,74
    FITEM,5,-81
    LSEL,S, , ,P51X
    LPLOT
    VPLOT
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    /ANG,1,30,XS,1
    /REP,FAST
    FINISH
    /POST1
    SAVE
    FINISH
    ! /EXIT,NOSAV
  3. Jun 10, 2015 #2
    Thanks for the post! This is an automated courtesy bump. Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
Have something to add?
Draft saved Draft deleted
