Solve k^2-1=a^2+b^2: Find Positive Ints
  • Thread starter AM-GM
In summary, there are infinite solutions for the equation k^2-1=a^2+b^2, as shown by choosing b to be even and using the fact that b^2+1 is odd. This applies to both prime and non-prime values of b, resulting in infinitely many solutions for all positive even values of b.
AM-GM
are there any positive integers k,a, b such that this equation is satisfied:
k^2-1=a^2+b^2
Yes, for example k = 9, a = 4, b = 8.
thanks, how do i go about proving that infinite solutions exist?
The solution
Here's the solution.
We have:
k^2-a^2=b^2-1
(k+a)(k-a)=b^2+1
Then choose b such that b is even.
This implies b^2+1 is odd. If b^2+1 is a prime, then put k+a=b^2+1 and k-a=1. You will get k&a. If b^2+1 is not a prime, then choose k+a and k-a as its two odd factors. Solving, you get k & a.
As there is solution for all b>0 and b even, there are infinitely many solutions.
You can see that Orthodontist's solution is also one of these.
the case with 1 is a special case of
k^2=a^2+b^2+c^2
a good question that might arose from this is what number is greater: the number of pythogrean triplets or the above qudroplets?
neither, they are both the same (countably infinite); it is not a difficulct question, and has indeed already been answered in this thread where it is asserted that there are infinitely many solutions to
k^2-1=a^2+b^2
We have:
k^2-a^2=b^2-1
(k+a)(k-a)=b^2+1
why should [itex]b[/itex] be even?
1. What is the equation "k^2-1=a^2+b^2" asking to solve?
The equation is asking to find two positive integers, a and b, such that when squared and added together, their sum is equal to k^2-1.
2. Is there a specific method for solving this type of equation?
Yes, there are several methods for solving this type of equation, including factoring, completing the square, and using the Pythagorean theorem.
3. Can you provide an example solution for this equation?
Sure, for the equation k^2-1=25+16, the positive integer solutions are a=3 and b=4, since 3^2+4^2=9+16=25=k^2-1.
4. Are there any restrictions on the values of k, a, and b in this equation?
Yes, k must be an odd number and a and b must be positive integers.
5. Can this equation be solved without using complex numbers?
Yes, this equation can be solved entirely with real numbers and does not require the use of complex numbers.
  • Linear and Abstract Algebra
