Anyone answer this calculation.
  • Thread starter jtesttubes
  • Tags
    Calculation
In summary, the conversation was about a question regarding the sum of money given over 30 days when starting with $1 and doubling it each day. The solution involves a geometric sum formula and results in a total of $1073741823.
I have been asked this question before 6 months, it was an interesting question.
Here is the question i just want to share.
Today let me simplify it as 1st day i give 1 $ 2nd Day i double it to 2$ I am going to give you like this for 30 days how much money i would have totally given at the end of 30 days... this is the question initially i thought simple and i found there is really a calculation behind it. I leave it to the members to find out the answer.
Sum((n-1)^2,n=1,30)
Don't know what the number is.
No, "doubling" would be [itex]2^{n-1}[/itex], not [itex](n-1)^2[/itex].
And the sum: [itex]\sum_{n=1}^{30} 2^{n-1}[/itex] is a geometric sum. A geometric sum is of the form [itex]\sum_{n=0}^N ar^{n-1}[/itex]. It is well known that it totals
[tex]a\frac{1- r^{N}}{1- r}[/tex]
For a= 1, r= 2, that is
[tex]\sum_{n=0}^N= \frac{1- 2^N}{1- 2}= 2^{N}- 1[/tex]
For n= 30, that is 230-1= 1073741823.
THanks Halls of Ivory. I switched the base and exponent.
Couldn't you just do
[tex]30!=2.6525286\cdot10^{32}[/tex]
Edit: Never mind, I read the original question wrong.
Ok david you have worked it out well, what is the answer in $
1. What is the purpose of this calculation?
The purpose of this calculation is to solve a specific problem or answer a question using mathematical operations and equations.
2. How accurate is this calculation?
The accuracy of a calculation depends on the data and equations used, as well as any potential errors in the input or calculations. It is important to double check and verify the results to ensure accuracy.
3. Can this calculation be done by hand or does it require a computer?
This depends on the complexity of the calculation and the level of precision needed. Some calculations can be done by hand using basic mathematical operations, while others may require a computer and specialized software.
4. What units should be used in this calculation?
The units used in a calculation should be consistent throughout the entire equation. It is important to convert units if necessary to ensure accurate results.
5. Are there any assumptions or limitations in this calculation?
Many calculations require certain assumptions or have limitations, such as ideal conditions or a specific range of values. It is important to understand these limitations and how they may affect the results of the calculation.
Suggested for: Anyone answer this calculation.
