Solving Aperture Question Homework: Diameter of Pupil
  • Thread starter toesockshoe
In summary, the conversation discusses finding the effective diameter of a person's pupil based on the maximum distance at which they can resolve two adjacent pixels on a computer monitor. Using the small angle formula and plugging in the appropriate values, the correct answer for the effective diameter is found to be 2.387 mm.
toesockshoe
265
A standard 14.16-inch (0.360-meter) computer monitor is 1024 pixels wide and 768 pixels tall. Each pixel is a square approximately 281micrometers on each side. Up close, you can see the individual pixels, but from a distance they appear to blend together and form the image on the screen.
If the maximum distance between the screen and your eyes at which you can just barely resolve two adjacent pixels is 1.30 meters, what is the effective diameter d of your pupil? Assume that the resolvability is diffraction-limited. Furthermore, use λ=550 nanometers as a characteristic optical wavelength.
[tex] sin(\theta) = \frac{1.22* \lambda}{D} [/tex]
using small angle formula, you can assume [tex] sin(\theta) = \theta [/tex] So, [tex] D = \frac {1.22 \lambda}{\theta} [/tex]. [tex] \theta = \frac{281}{10^6} [/tex] .. AND [tex] \lambda = \frac{550}{10^9} [/tex]. Plugging all these values in, I get D=2.387 mm which is incorrect according to the homework checker. Where am I going wrong?
toesockshoe said:
##\theta = \frac{281}{10^6}##
Hello. Can you explain why the above expression represents θ? If you were to include units with your numbers, would you get the correct units for θ?
It is 281micrometers/10^6 micrometers. This would be dimensionless which is a valid argument for theta.
It is equivalently 281 times 10^-6 m/1m.
Why the 1 m in the denominator?
should it be 1.3m in the denominator instead? because tantheta is approx sin theta for small angles? ... i still don't get right answer.
Forget the numbers for a moment. Let's make sure we understand the concept. Can you describe in words how to find θ?
yeah... you can use tan^-1(opposite/adjacent). opp is the distance between 2 pixels, and adj distance is the distance from you to the screen (which is 1.3). we have the opp distance and adj distance so we can find theta. units, cancel out because you are dividing meters/meters... and you have an acceptable angle measure.
OK, that will work for small angles. For small angles you can go on and approximate d/L by θ (in radians), where d is distance between pixels and L is distance from eye to pixels. So, yes, you should be dividing by 1.3 m.
I'm not sure why you are not getting the right answer now. What are you getting for D?
I got it. thank you.
Good work.
1. What is the purpose of solving aperture question homework?
The purpose of solving aperture question homework is to understand the concept of aperture and its relationship to the diameter of a pupil. It also allows students to practice calculations and problem-solving skills related to this topic.
2. How do I determine the diameter of a pupil?
The diameter of a pupil can be determined by using the formula: D = 2A/F, where D is the diameter of the pupil, A is the aperture, and F is the focal length of the lens.
3. What is the significance of the diameter of a pupil?
The diameter of a pupil is significant because it determines the amount of light that enters the eye. A larger pupil allows more light to enter, while a smaller pupil restricts the amount of light. This affects the clarity and brightness of the image that is perceived by the eye.
4. How does the diameter of a pupil change in different lighting conditions?
The diameter of a pupil changes in response to the amount of light available. In bright light, the pupil constricts to limit the amount of light entering the eye. In dim light, the pupil dilates to allow more light to enter and improve vision in low light conditions.
5. What are some real-life applications of understanding the diameter of a pupil?
Understanding the diameter of a pupil is important in various fields, such as photography, optometry, and ophthalmology. It also has practical applications in everyday life, such as adjusting the aperture setting on a camera for optimal lighting, and understanding how our eyes adapt to different lighting conditions.
26K
