Apparent Magnitude: Meaning & 3 Star System
In summary, the apparent magnitude of a star refers to how bright it appears from Earth, and is measured on a logarithmic scale from 0 to 6. The system of 3 stars could mean comparing the unknown star to 3 known stars nearby, or using each magnitude being 2.5 times fainter than the previous one. To obtain combined brightness of individual stars, the individual magnitudes must be converted to luminosity, added together, and then converted back to magnitude. The unit of apparent magnitude is not the same as brightness, and it was first established by Hipparchus.
Magister
83
What is the meaning of: "the apparent magnitude of a star is obtain with a system of 3 stars"?
Thanks
Astronomy news on Phys.org
"apparent magnitude" is how bright a star looks from earth.
It's on a rather odd log scale from 0=brightest, 6 is the about the limit with your eye, 26 is about the record for a big telescope.
Not sure about the "system of 3 stars" could mean either that you compare the unknown star with 3 known stars nearby ( is this the delta cephei experiment) .
The star Vega used to be defined as magnitude 0 but then you just use each magnitude being 2.5 times fainter than the previous - there is no standard mag=1,2,3 etc star.
Sounds live an equivalent single star brightness question. The magnitude scale is logarithmic, so magnitudes do not multiply of divide linearly. For example 3 stars of apparent magnitude 3 would collectively appear about as bright as one star of apparent magnitude 1.8. The most straightforward way to obtain combined brightness of individual stars is to convert each individual magnitudes to luminosity, add them up and then convert back to magnitude.
"Apparent magnitude" is a kind of brightness quantity. But as you guess, brightness depends on the distance between observer and a object. Apparent magnitude is just the brightness, when you observe it from the Earth with, or from space telescope from space. But be careful, its unit is not just the same with brightness(whose is energy/time). After Hipparchus, who was the first sky watcher to determine the locations of the stars, and he also labeled the brightest star as 1 magnitude, and the faintest with 6 magnitude.
1. What is apparent magnitude?
Apparent magnitude is a measure of the brightness of a celestial object as seen from Earth. It is based on the amount of light that reaches the observer's eye and is affected by factors such as distance, size, and intrinsic brightness of the object.
2. How is apparent magnitude measured?
Apparent magnitude is measured on a logarithmic scale, with lower numbers indicating brighter objects and higher numbers indicating dimmer objects. Each decrease in magnitude by 1 corresponds to an increase in brightness by a factor of 2.5.
3. What is the meaning of a negative apparent magnitude?
A negative apparent magnitude indicates that the object is extremely bright, with the brightest objects having magnitudes as low as -26.74 (such as the sun). It is important to note that negative magnitudes are only used for the brightest objects and not all objects have negative magnitudes.
4. How does apparent magnitude relate to absolute magnitude?
Apparent magnitude is a measure of an object's brightness as seen from Earth, while absolute magnitude is a measure of its intrinsic brightness. Absolute magnitude takes into account distance, so two objects with the same absolute magnitude may have different apparent magnitudes if they are at different distances from Earth.
5. How does a 3 star system affect apparent magnitude?
In a 3 star system, the apparent magnitude will depend on the combined brightness of all three stars. If all three stars have similar magnitudes, the combined apparent magnitude will be brighter than a single star. However, if one star is significantly brighter than the other two, it will have a greater impact on the overall apparent magnitude of the system.
  • Astronomy and Astrophysics
