Application of momentum conservation in inelastic collisions
In summary: Yes. Momentum is conserved within a system (your block) if and only if there are no externally applied forces.Momentum is conserved within a system (your block) if and only if there are no externally applied forces.
burian
64
A small block of mass M moves on a frictionless surface on an inclined plane, as shown in the figure. The angle of the incline suddenly changes from 60 to 30 at point B. The block is initially rest at A
$$ \frac{mv^2}{2} = mgh$$
So, what I did was suppose the mass of ramp is $ M_r$ and let velocity at B of block be v, then, after inellastic collsion both bodies v' velocity
at B ,
$$M\vec{v}= M_r \vec{v'}+ M \vec{v'}$$
or,
$$ \frac{M}{M +M_r} \vec{v}= \vec{v'}$$
Now,
Suppose I take the limit as mass of ramp goes to infinity, then I get $\vec{ v'}=0$
that means, after the collision, the block is temporarily at rest and then slides to ground.So, we can just neglect upper half and do energy conservation in lower half ramp to get velocity at final position.
However, my answer came out wrong for some reason, I wish to ask if my concepts are correct?
answer I got:
$$| v|= \sqrt{60}$$
actual answer:
$$| v|= \sqrt{105}$$
Velocity and momentum are vector quantities.
@PeroK I have put the vector arrows on top but how does go to my mistake?
What do you think happens when the mass ##m## hits the lower ramp?
PS What would happen if the second ramp were horizontal and the first ramp at ##30°## to it?
as shown with equations, it should have it's velocity drop to 0 because of the large mass of block
I can't guess
Velocity is a vector quantity. You need to think about its components.
burian said:
I can't guess
That's what you need to work out using the velocity vector.
Why? can't I just write momentum conservation in a vector form 🤔
Are you suggesting there is impulse in one of the directions? I considered that there would be an impulse when the block hits the second surface but neglected it coz the time period shouldbe small where they collide 🧐
burian said:
actual answer:v|=105
The answer you refer seems the speed just before the ramp C. After the ramp C the block goes horizontally with reduced speed by factor of ##\frac{\sqrt{3}}{2}## as well as at ramp B.
"The angle of the incline suddenly changes"
The thing about sudden impacts is that although the duration is brief (and in general unknown) the forces can be very large and unknown. So the integral of the force over the duration, i.e. the net change in momentum, can be significant.
To make @PeroK's point more starkly, what if the first ramp were vertical and the second horizontal?
burian said:
Homework Statement:: A small block of mass M moves on a frictionless surface on an inclined plane, as shown in the figure. The angle of the incline suddenly changes from 60 to 30 at point B. The block is initially rest at A
Relevant Equations:: $$ \frac{mv^2}{2} = mgh$$
at B ,
or,
Now,
answer I got:
$$| v|= \sqrt{60}$$
actual answer:
what is the question?
plus: momentum is conserved within a system (your block) if and only if there are no externally applied forces.
Burt there is gravity and the upward push on the block.
So is momentum conservation applicable to solve whatever your question is?
At the ramp boundary, yes.
Yes.
So we can assume the question is velocity before & after moment of impact.
A vector equation gives you two or three separate equations, one for each vector component. Momentum may be conserved in one direction but not in another, as in this case.
Consider throwing a ball horizontally. When it hits the floor the horizontal momentum is approximately conserved, but the vertical momentum is approximately reversed. The two components change in very different ways as a result of the bounce.
Usually we say can apply momentum consv in vertical direction coz the time period gravity acts over is small
Mhm I see, I wam looking for a description of this impuslive force which happens
You did not answer my question.
If the first ramp were vertical and fhe second horizontal, what would you expect the velocity of the block to be after meeting the second ramp?
I would guess that it becomes zero. But maybe it may bounce as well hmm
The bouncing you are expected to ignore!
hmm I think I understand now, along normal the momentum not conserved but along surface it is. But one thing though, I still seek a more elaborate description of what exactly is happenign which makes this normal impulse not negligible in comparison to gravity in collisions
Let's see some analysis of the problem from you. Can you solve this using the velocity vector?
See my hint about modelling the collision in post #5.
Suppose that the collision is slow. Let us say that it acts for a duration ##\Delta t##. Over the course of that duration the force of gravity has time to act. The amount of momentum delivered by a force F over a time ##\Delta t## is given by ##\Delta p=F \Delta t##.
If the collision is faster, gravity has less time to act. The amount of momentum delivered by gravity is lower. For an ideal collision that takes no time at all, gravity has time to deliver no momentum at all.
It can be useful to think of forces as trickles of momentum flowing into an object over time. An impulse can be thought of as a lump delivery -- a chunk of momentum arriving all at once.
By analogy, think of your kitchen sink. The drain is leaking and water is trickling out. [That's gravity]. You dump a half-gallon pitcher of water in all at once. [That's the impulse from the collision]. You can measure the water in the sink before and after. As long as you measure fast, it's it is a plus half a gallon difference. You can ignore the trickle going down the drain.
I think I get the idea now,
$$ v'\sin \theta = \sqrt{2 gh}$$
is the final equation that I had got
here the $$\theta$$ is angle of ramp, I got this equation by finding component of velocity post collision parallel to ramp. And v' is the final velocity (i.e: velocity after it gets out of ramp)
Now that I have this, could you tell me how to describe the impulse which occurs to component perpendicular to ramp?
That doesn't look right.
The idea is that the object loses all its momentum in the direction normal to the ramp it collides with and none of its momentum in the direction tangential to the ramp it collides with.
Therefore, you have to calculate the components of velocity (normal and tangential to the ramp) at the time of collision. The velocity after the collision is the tangential component only.
That's the idea. Now you have to do the calculations.
Hmm I did this by drawing a diagram after collision I'm not sure how the diagram would be right at collision. But I drew this
I can't figure out how to draw it right at collision, I'm thinking that it may chance of tipping over , how do I know if tips over or not? 🤔 🤔 🧐🤔🤔
In that diagram you really want to show the components of ##v## before the collision. And, especially how ##v'## relates to them.
You're not supposed to worry about the object bouncing or tipping over!
It's always worth running a sanity check. Does your expression give a sensible answer when the first surface is at right angles to the second?
You know that what is preserved is the component of momentum parallel to the second surface, so resolve the momentum before impact into components parallel and normal to the second surface.
1. How is momentum conserved in inelastic collisions?
According to the law of conservation of momentum, the total momentum of a system remains constant before and after a collision. In inelastic collisions, the objects involved stick together and move with a common velocity after the collision, thus conserving the total momentum of the system.
2. What is the formula for calculating momentum in inelastic collisions?
The formula for calculating momentum in inelastic collisions is p = m1v1 + m2v2, where p is the total momentum of the system, m1 and m2 are the masses of the objects involved, and v1 and v2 are their velocities before the collision.
3. How does the coefficient of restitution affect momentum conservation in inelastic collisions?
The coefficient of restitution is a measure of the elasticity of a collision. In inelastic collisions, the coefficient of restitution is less than 1, meaning that some of the kinetic energy is lost during the collision. This does not affect momentum conservation, as the total momentum of the system remains constant.
4. Can momentum be conserved in completely inelastic collisions?
Yes, momentum can still be conserved in completely inelastic collisions. In these types of collisions, the objects involved stick together and move with a common velocity after the collision. This means that the total momentum of the system remains constant, even though some kinetic energy is lost.
5. What are some real-life examples of inelastic collisions?
Some real-life examples of inelastic collisions include car accidents, where the cars involved stick together after the collision, and pool balls colliding, where the balls stick together and move with a common velocity after the collision. In both cases, momentum is conserved despite some kinetic energy being lost.
