1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Application of Stokes Theorem
  1. Dec 2, 2009 #1
    Use Stokes's Theorem to evaluate [tex]\int F · dr[/tex]
    In this case, C (the curve) is oriented counterclockwise as viewed from above.
    2. Relevant equations
    F(x,y,z) = xyzi + yj + zk, x2 + y2 ≤ a2
    S: the first-octant portion of z = x2 over x2 + y2 = a2
    3. The attempt at a solution
    "Use Stoke's" is code for "stick the dot product of curl F and the normal vector into the integral". If this problem behaves nicely, this should become a double integral like every other Stoke's problem in the book and will need a new area of integration as well.
    curl F would be <0, xy-yz, -xz>
    G(x,y) = z-x2
    the normal is <-Gx,-Gy,1>
    which is <-2x, 0, 1>
    F · N = 0+0-xz = -xz because of convenient canceling
    So now -xz has to be integrated over some area. The "first octant" is simple enough, and x2 + y2 ≤ a2 is a cylinder of infinite height and radius a centered around the Z-axis (a fixed circle for every Z). I'm picturing a a parabola-cum-trough looking thing that got stamped by a circular cookie cutter.
    If that's the case, the x's get restricted which means the z's get restricted to a constant. How do you set up the integral to get rid of all variables (the radius a is a constant and obviously stays undefined).
Draft saved Draft deleted
Similar Threads - Application Stokes Theorem Date
Stoke's Theorem Application Dec 1, 2016
Stokes' theorem application Nov 29, 2013
Possible application of Stoke's Theorem Nov 10, 2012
Stokes theorem application Dec 4, 2011
Application of Stokes' theorem Jul 28, 2010
