Solving Train & Camera Motion Questions: a & b
In summary: The part of the track closest to the camera will also be tangent to the circle formed by the camera, and the radius of that circle should be 1 km.In summary, the problem involves a train traveling at a constant speed along a straight track and a movie camera focused on the train from 1km away. The first part of the problem asks for the rate at which the distance between the camera and the train is changing when the train is 2km away, while the second part asks for the camera's rate of rotation at that moment. To solve this, a right triangle can be formed between the camera, train, and closest point on the track, with the part of the track closest to the camera being tangent to the circle
yangxu
A train is traveling from left to right along a long straight horizontal track at 0.9km/min. A movie camera 1km away from the train is focused on the train.
a) How fast is the distance between the camera and the train changing when the train is 2km from the camera?
b) How fast is the camera rotating (in radians/min) at the moment when the train is 2km from the camera?
I'm not sure how the equations should be written, most of the questions I've seen are lights on a pole (telling you its height and position) with an object moving toward or away from it, thus allowing trigonometric equations to be set up.
Part a) makes it sound like it's going to be a linear equation with no trigonometry involved, but part b) confuses me with the camera's rate of rotation. Any help on how I should write the equations for these two parts is highly appreciated. Thanks in advance.
I think the problem means for you to draw a line from the camera to a specific point on the train, say, the "nose" of the locomotive. However, something seems very sloppy about the way the problem is written. It seems they should mean that the perpendicular distance from the camera to the track is 1 km. Otherwise, you have no way to figure out distances and angles; also, the train is plainly not both 1 and 2 km. from the camera in the parts of the problem.
It will be important from here to draw a picture of the situation. There will now be a right triangle formed between camera, train, and closest point on the track.
1. How do you calculate the speed of a train using camera footage?
To calculate the speed of a train using camera footage, you need to know the distance between two points on the track and the time it takes the train to travel between those points. You can use the formula Speed = Distance/Time to calculate the speed of the train.
2. Can camera footage be used to determine the acceleration of a train?
Yes, camera footage can be used to determine the acceleration of a train. By measuring the change in velocity over a specific time interval, you can calculate the acceleration using the formula Acceleration = (Final Velocity - Initial Velocity)/Time.
3. How do you account for camera angles and perspective when analyzing train motion?
To account for camera angles and perspective, you can use trigonometry to calculate the actual distance traveled by the train. By measuring the angle of the camera in relation to the track and using the distance formula, you can determine the true distance traveled by the train.
4. Can train motion be analyzed using multiple camera angles?
Yes, analyzing train motion using multiple camera angles can provide a more accurate understanding of the train's speed and acceleration. By using multiple angles, you can account for any discrepancies or distortions caused by a single camera angle.
5. Is it necessary to know the exact location of the camera in order to analyze train motion?
No, it is not necessary to know the exact location of the camera. As long as you have accurate measurements of the distance between two points on the track and the time it takes the train to travel between those points, you can calculate the train's speed and acceleration without knowing the camera's exact location.
  • General Engineering
  • Computing and Technology
